I am working on sending a model trained with RapidMiner to an endpoint via AI Hub, and then receiving it through a REST API on another site. The deployment has been successful, but when I test the endpoint, modifying the test request's input data still results in the same test result. This also happens when I use the endpoint URL in RapidMiner's REST API and include key-value pairs in the body. What could be the issue?
