<?xml version="1.0" encoding="UTF-8"?><process version="10.3.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="10.3.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="read_csv" compatibility="10.3.001" expanded="true" height="68" name="Read CSV" width="90" x="45" y="136"> <parameter key="csv_file" value="https://us.v-cdn.net/6038102/uploads/editor/wi/9fdij6pl08ak.csv"/> <parameter key="column_separators" value=","/> <parameter key="trim_lines" value="false"/> <parameter key="multiline_text" value="false"/> <parameter key="use_quotes" value="true"/> <parameter key="quotes_character" value="""/> <parameter key="escape_character" value="\"/> <parameter key="skip_comments" value="true"/> <parameter key="comment_characters" value="#"/> <parameter key="starting_row" value="1"/> <parameter key="parse_numbers" value="true"/> <parameter key="decimal_character" value="."/> <parameter key="grouped_digits" value="false"/> <parameter key="grouping_character" value=","/> <parameter key="infinity_representation" value=""/> <parameter key="date_format" value="dd-MM-yyyy"/> <parameter key="use_header_row" value="true"/> <parameter key="header_row" value="1"/> <parameter key="first_row_as_names" value="true"/> <list key="annotations"/> <parameter key="time_zone" value="Europe/Berlin"/> <parameter key="locale" value="English (United States)"/> <parameter key="encoding" value="windows-1252"/> <parameter key="read_all_values_as_polynominal" value="false"/> <list key="data_set_meta_data_information"> <parameter key="0" value="ID.true.integer.attribute"/> <parameter key="1" value="Year_Birth.true.integer.attribute"/> <parameter key="2" value="Education.true.polynominal.attribute"/> <parameter key="3" value="Marital_Status.true.polynominal.attribute"/> <parameter key="4" value="Income.true.integer.attribute"/> <parameter key="5" value="Kidhome.true.integer.attribute"/> <parameter key="6" value="Teenhome.true.integer.attribute"/> <parameter key="7" value="Dt_Customer.true.date.attribute"/> <parameter key="8" value="Recency.true.integer.attribute"/> <parameter key="9" value="MntWines.true.integer.attribute"/> <parameter key="10" value="MntFruits.true.integer.attribute"/> <parameter key="11" value="MntMeatProducts.true.integer.attribute"/> <parameter key="12" value="MntFishProducts.true.integer.attribute"/> <parameter key="13" value="MntSweetProducts.true.integer.attribute"/> <parameter key="14" value="MntGoldProds.true.integer.attribute"/> <parameter key="15" value="NumDealsPurchases.true.integer.attribute"/> <parameter key="16" value="NumWebPurchases.true.integer.attribute"/> <parameter key="17" value="NumCatalogPurchases.true.integer.attribute"/> <parameter key="18" value="NumStorePurchases.true.integer.attribute"/> <parameter key="19" value="NumWebVisitsMonth.true.integer.attribute"/> <parameter key="20" value="AcceptedCmp3.true.integer.attribute"/> <parameter key="21" value="AcceptedCmp4.true.integer.attribute"/> <parameter key="22" value="AcceptedCmp5.true.integer.attribute"/> <parameter key="23" value="AcceptedCmp1.true.integer.attribute"/> <parameter key="24" value="AcceptedCmp2.true.integer.attribute"/> <parameter key="25" value="Complain.true.integer.attribute"/> <parameter key="26" value="Response.true.integer.attribute"/> </list> <parameter key="read_not_matching_values_as_missings" value="false"/> <description align="center" color="transparent" colored="false" width="126">Read the CSV</description> </operator> <operator activated="true" class="blending:select_attributes" compatibility="10.3.001" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="136"> <parameter key="type" value="include attributes"/> <parameter key="attribute_filter_type" value="one attribute"/> <parameter key="select_attribute" value="Marital_Status"/> <parameter key="select_subset" value=""/> <parameter key="also_apply_to_special_attributes_(id,_label..)" value="false"/> <description align="center" color="transparent" colored="false" width="126">Only select the Maritial_Status</description> </operator> <operator activated="true" class="multiply" compatibility="10.3.001" expanded="true" height="103" name="Multiply" width="90" x="313" y="136"/> <operator activated="true" class="nominal_to_numerical" compatibility="10.3.001" expanded="true" height="103" name="Unique Integers (Nominal to Numerical)" width="90" x="514" y="238"> <parameter key="return_preprocessing_model" value="false"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="coding_type" value="unique integers"/> <parameter key="use_comparison_groups" value="false"/> <list key="comparison_groups"/> <parameter key="unexpected_value_handling" value="all 0 and warning"/> <parameter key="use_underscore_in_name" value="false"/> </operator> <operator activated="true" class="nominal_to_numerical" compatibility="10.3.001" expanded="true" height="103" name="Dummy Encoding (Nominal to Numerical)" width="90" x="514" y="34"> <parameter key="return_preprocessing_model" value="false"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="coding_type" value="dummy coding"/> <parameter key="use_comparison_groups" value="false"/> <list key="comparison_groups"/> <parameter key="unexpected_value_handling" value="all 0 and warning"/> <parameter key="use_underscore_in_name" value="false"/> </operator> <connect from_op="Read CSV" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Dummy Encoding (Nominal to Numerical)" to_port="example set input"/> <connect from_op="Multiply" from_port="output 2" to_op="Unique Integers (Nominal to Numerical)" to_port="example set input"/> <connect from_op="Unique Integers (Nominal to Numerical)" from_port="example set output" to_port="result 2"/> <connect from_op="Dummy Encoding (Nominal to Numerical)" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator> </process>
