<?xml version="1.0" encoding="UTF-8"?><process version="10.3.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="10.3.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="utility:create_exampleset" compatibility="10.3.001" expanded="true" height="68" name="Create ExampleSet" width="90" x="45" y="85"> <parameter key="generator_type" value="comma separated text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="input_csv_text" value="T/F T, T, T, F, F, F, F, F, T, F, F, F "/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="time_series:lag_series_with_default_lag" compatibility="10.3.001" expanded="true" height="82" name="Lag" width="90" x="179" y="85"> <list key="individual_lags"> <parameter key="T/F" value="1"/> </list> <parameter key="add_default_lag" value="false"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="default_lag" value="1"/> <parameter key="overwrite_attributes" value="false"/> <parameter key="extend_exampleset" value="true"/> </operator> <operator activated="true" class="time_series:replace_missing_values" compatibility="10.3.001" expanded="true" height="68" name="Replace Missing Values (Series)" width="90" x="313" y="85"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="T/F-1"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="has_indices" value="false"/> <parameter key="indices_attribute" value=""/> <parameter key="sort_time_series" value="false"/> <parameter key="overwrite_attributes" value="true"/> <parameter key="new_attributes_postfix" value="_cleaned"/> <parameter key="replace_type_numerical" value="previous value"/> <parameter key="replace_type_nominal" value="previous value"/> <parameter key="replace_type_date_time" value="previous value"/> <parameter key="replace_value_numerical" value="0.0"/> <parameter key="replace_value_nominal" value="unknown"/> <parameter key="skip_other_missings" value="true"/> <parameter key="replace_infinity" value="true"/> <parameter key="replace_empty_strings" value="true"/> <parameter key="ensure_finite_values" value="false"/> </operator> <operator activated="true" class="blending:generate_id" compatibility="10.3.001" expanded="true" height="82" name="Generate ID" width="90" x="447" y="85"> <parameter key="create_nominal_ids" value="false"/> <parameter key="offset" value="0"/> </operator> <operator activated="true" class="blending:set_role" compatibility="10.3.001" expanded="true" height="82" name="Set Role" width="90" x="581" y="85"> <list key="set_roles"> <parameter key="id" value="regular"/> </list> </operator> <operator activated="true" class="blending:generate_columns" compatibility="10.3.001" expanded="true" height="82" name="Generate Attributes (2)" width="90" x="715" y="85"> <list key="function_descriptions"> <parameter key="Counter" value="if([T/F]==[T/F-1],"xy",str(id))"/> </list> <parameter key="keep_all_columns" value="true"/> </operator> <operator activated="true" class="replace" compatibility="10.3.001" expanded="true" height="82" name="Replace" width="90" x="849" y="85"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Counter"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="replace_what" value="xy"/> </operator> <operator activated="true" class="time_series:replace_missing_values" compatibility="10.3.001" expanded="true" height="68" name="Replace Missing Values (Series) (2)" width="90" x="983" y="85"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Counter"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="has_indices" value="false"/> <parameter key="indices_attribute" value=""/> <parameter key="sort_time_series" value="false"/> <parameter key="overwrite_attributes" value="true"/> <parameter key="new_attributes_postfix" value="_cleaned"/> <parameter key="replace_type_numerical" value="previous value"/> <parameter key="replace_type_nominal" value="previous value"/> <parameter key="replace_type_date_time" value="previous value"/> <parameter key="replace_value_numerical" value="0.0"/> <parameter key="replace_value_nominal" value="unknown"/> <parameter key="skip_other_missings" value="true"/> <parameter key="replace_infinity" value="true"/> <parameter key="replace_empty_strings" value="true"/> <parameter key="ensure_finite_values" value="false"/> </operator> <operator activated="true" class="numerical_to_polynominal" compatibility="10.3.001" expanded="true" height="82" name="Numerical to Polynominal" width="90" x="1117" y="85"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="id"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="real"/> <parameter key="block_type" value="value_series"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_series_end"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <operator activated="true" class="concurrency:loop_values" compatibility="10.3.001" expanded="true" height="82" name="Loop Values" width="90" x="1251" y="85"> <parameter key="attribute" value="id"/> <parameter key="iteration_macro" value="loop_value"/> <parameter key="reuse_results" value="false"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="filter_examples" compatibility="10.3.001" expanded="true" height="103" name="Filter Examples" width="90" x="179" y="34"> <parameter key="parameter_expression" value=""/> <parameter key="condition_class" value="custom_filters"/> <parameter key="invert_filter" value="false"/> <list key="filters_list"> <parameter key="filters_entry_key" value="Counter.equals.%{loop_value}"/> </list> <parameter key="filters_logic_and" value="true"/> <parameter key="filters_check_metadata" value="true"/> </operator> <operator activated="true" class="blending:generate_id" compatibility="10.3.001" expanded="true" height="82" name="Generate ID (2)" width="90" x="313" y="34"> <parameter key="create_nominal_ids" value="false"/> <parameter key="offset" value="-1"/> </operator> <operator activated="true" class="blending:set_role" compatibility="10.3.001" expanded="true" height="82" name="Set Role (2)" width="90" x="447" y="34"> <list key="set_roles"> <parameter key="id" value="regular"/> </list> </operator> <operator activated="true" class="blending:select_attributes" compatibility="10.3.001" expanded="true" height="82" name="Select Attributes" width="90" x="581" y="34"> <parameter key="type" value="include attributes"/> <parameter key="attribute_filter_type" value="a subset"/> <parameter key="select_attribute" value=""/> <parameter key="select_subset" value="id␞T/F␞Counter"/> <parameter key="also_apply_to_special_attributes_(id,_label..)" value="false"/> </operator> <operator activated="true" class="filter_examples" compatibility="10.3.001" expanded="true" height="103" name="Filter Examples (2)" width="90" x="715" y="34"> <parameter key="parameter_expression" value=""/> <parameter key="condition_class" value="no_missing_attributes"/> <parameter key="invert_filter" value="false"/> <list key="filters_list"/> <parameter key="filters_logic_and" value="true"/> <parameter key="filters_check_metadata" value="true"/> </operator> <connect from_port="input 1" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Generate ID (2)" to_port="example set input"/> <connect from_op="Generate ID (2)" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/> <connect from_op="Set Role (2)" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Filter Examples (2)" to_port="example set input"/> <connect from_op="Filter Examples (2)" from_port="example set output" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="operator_toolbox:advanced_append" compatibility="2.17.000" expanded="true" height="82" name="Append (Superset)" width="90" x="1385" y="85"/> <connect from_op="Create ExampleSet" from_port="output" to_op="Lag" to_port="example set input"/> <connect from_op="Lag" from_port="example set output" to_op="Replace Missing Values (Series)" to_port="example set"/> <connect from_op="Replace Missing Values (Series)" from_port="example set" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Generate Attributes (2)" to_port="table input"/> <connect from_op="Generate Attributes (2)" from_port="table output" to_op="Replace" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_op="Replace Missing Values (Series) (2)" to_port="example set"/> <connect from_op="Replace Missing Values (Series) (2)" from_port="example set" to_op="Numerical to Polynominal" to_port="example set input"/> <connect from_op="Numerical to Polynominal" from_port="example set output" to_op="Loop Values" to_port="input 1"/> <connect from_op="Loop Values" from_port="output 1" to_op="Append (Superset)" to_port="example set 1"/> <connect from_op="Append (Superset)" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
