<?xml version="1.0" encoding="UTF-8"?><process version="10.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="10.3.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="UTF-8"/> <process expanded="true"> <operator activated="true" breakpoints="after" class="retrieve" compatibility="10.3.000" expanded="true" height="68" name="Retrieve Golf" width="90" x="45" y="34"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="concurrency:loop_attributes" compatibility="10.3.000" expanded="true" height="82" name="Loop Attributes" width="90" x="179" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="attribute_name_macro" value="loop_attribute"/> <parameter key="reuse_results" value="true"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="handle_exception" compatibility="10.3.000" expanded="true" height="82" name="Handle Exception" width="90" x="112" y="34"> <parameter key="add_details_to_log" value="false"/> <process expanded="true"> <operator activated="true" class="generate_macro" compatibility="10.3.000" expanded="true" height="82" name="Generate Macro" width="90" x="45" y="34"> <list key="function_descriptions"> <parameter key="new_name" value="cut(%{loop_attribute},0,4)"/> </list> </operator> <operator activated="true" class="blending:rename" compatibility="10.3.000" expanded="true" height="82" name="Rename" width="90" x="179" y="34"> <list key="rename attributes"> <parameter key="%{loop_attribute}" value="%{new_name}"/> </list> <parameter key="from_attribute" value=""/> <parameter key="to_attribute" value=""/> </operator> <connect from_port="in 1" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> <process expanded="true"> <connect from_port="in 1" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_port="input 1" to_op="Handle Exception" to_port="in 1"/> <connect from_op="Handle Exception" from_port="out 1" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve Golf" from_port="output" to_op="Loop Attributes" to_port="input 1"/> <connect from_op="Loop Attributes" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
<?xml version="1.0" encoding="UTF-8"?><process version="10.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="10.3.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="UTF-8"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="10.3.000" expanded="true" height="68" name="Retrieve Titanic" width="90" x="45" y="34"> <parameter key="repository_entry" value="//Samples/data/Titanic"/> <description align="center" color="transparent" colored="false" width="126">Replace this with your dataset</description> </operator> <operator activated="true" class="transpose" compatibility="10.3.000" expanded="true" height="82" name="Transpose" width="90" x="179" y="34"/> <operator activated="true" class="rename_by_generic_names" compatibility="10.3.000" expanded="true" height="82" name="Rename by Generic Names" width="90" x="514" y="289"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="generic_name_stem" value="att"/> </operator> <operator activated="true" class="blending:select_attributes" compatibility="10.3.000" expanded="true" height="82" name="Select column names" width="90" x="313" y="34"> <parameter key="type" value="include attributes"/> <parameter key="attribute_filter_type" value="one attribute"/> <parameter key="select_attribute" value="id"/> <parameter key="select_subset" value=""/> <parameter key="also_apply_to_special_attributes_(id,_label..)" value="true"/> <description align="center" color="transparent" colored="false" width="126"/> </operator> <operator activated="true" class="generative_models:summarization" compatibility="1.0.000" expanded="true" height="82" name="Summarization" origin="GENERATED_TUTORIAL" width="90" x="447" y="34"> <parameter key="conda_environment" value="rm_genai"/> <parameter key="use_local_model" value="false"/> <parameter key="model" value="Falconsai/text_summarization"/> <parameter key="name" value="summary"/> <parameter key="prompt" value="[[id]]"/> <parameter key="min_target_length" value="2"/> <parameter key="max_target_length" value="5"/> <parameter key="device" value="Automatic"/> <parameter key="device_indices" value="0"/> <parameter key="temperature" value="1.0"/> <description align="center" color="transparent" colored="false" width="126">Apply the model to the prompts and deliver the results</description> </operator> <operator activated="true" class="blending:select_attributes" compatibility="10.3.000" expanded="true" height="82" name="Drop original" width="90" x="45" y="289"> <parameter key="type" value="include attributes"/> <parameter key="attribute_filter_type" value="one attribute"/> <parameter key="select_attribute" value="summary"/> <parameter key="select_subset" value=""/> <parameter key="also_apply_to_special_attributes_(id,_label..)" value="true"/> </operator> <operator activated="true" class="transpose" compatibility="10.3.000" expanded="true" height="82" name="Transpose back" width="90" x="179" y="289"/> <operator activated="true" class="blending:select_attributes" compatibility="10.3.000" expanded="true" height="82" name="Drop id" width="90" x="313" y="289"> <parameter key="type" value="exclude attributes"/> <parameter key="attribute_filter_type" value="one attribute"/> <parameter key="select_attribute" value="id"/> <parameter key="select_subset" value=""/> <parameter key="also_apply_to_special_attributes_(id,_label..)" value="true"/> </operator> <operator activated="true" class="rename_by_generic_names" compatibility="10.3.000" expanded="true" height="82" name="Rename by Generic Names (2)" width="90" x="514" y="187"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="generic_name_stem" value="att"/> </operator> <operator activated="true" class="numerical_to_polynominal" compatibility="10.3.000" expanded="true" height="82" name="Numerical to Polynominal" width="90" x="648" y="289"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="real"/> <parameter key="block_type" value="value_series"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_series_end"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <operator activated="true" class="append" compatibility="10.3.000" expanded="true" height="103" name="Append" width="90" x="648" y="34"> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> <parameter key="merge_type" value="all"/> </operator> <operator activated="true" class="blending:rename_by_example_values" compatibility="10.3.000" expanded="true" height="82" name="Rename by Example Values" width="90" x="782" y="34"> <parameter key="row_number" value="1"/> </operator> <operator activated="true" class="parse_numbers" compatibility="10.3.000" expanded="true" height="82" name="Parse Numbers" width="90" x="916" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="decimal_character" value="."/> <parameter key="grouped_digits" value="false"/> <parameter key="grouping_character" value=","/> <parameter key="infinity_representation" value=""/> <parameter key="unparsable_value_handling" value="skip attribute"/> </operator> <connect from_op="Retrieve Titanic" from_port="output" to_op="Transpose" to_port="example set input"/> <connect from_op="Transpose" from_port="example set output" to_op="Select column names" to_port="example set input"/> <connect from_op="Transpose" from_port="original" to_op="Rename by Generic Names" to_port="example set input"/> <connect from_op="Rename by Generic Names" from_port="example set output" to_op="Numerical to Polynominal" to_port="example set input"/> <connect from_op="Select column names" from_port="example set output" to_op="Summarization" to_port="input 1"/> <connect from_op="Summarization" from_port="result 1" to_op="Drop original" to_port="example set input"/> <connect from_op="Drop original" from_port="example set output" to_op="Transpose back" to_port="example set input"/> <connect from_op="Transpose back" from_port="example set output" to_op="Drop id" to_port="example set input"/> <connect from_op="Drop id" from_port="example set output" to_op="Rename by Generic Names (2)" to_port="example set input"/> <connect from_op="Rename by Generic Names (2)" from_port="example set output" to_op="Append" to_port="example set 1"/> <connect from_op="Numerical to Polynominal" from_port="example set output" to_op="Append" to_port="example set 2"/> <connect from_op="Append" from_port="merged set" to_op="Rename by Example Values" to_port="example set input"/> <connect from_op="Rename by Example Values" from_port="example set output" to_op="Parse Numbers" to_port="example set input"/> <connect from_op="Parse Numbers" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
