Column Configuration error
Dessanya1
Hello, I imported a csv file and i have two column configuration errors
1. "The column 9,11,12,13 have the same name '0'
2. ''The column 7 and 10 have the same name '1'
I feel stuck and don't know how to proceed
Errors
Configuration
Caperez
Hi
@Dessanya1
are you using the wizard menu to import the file?
There you have the option to change the name, type etc.
best,
Cesar
RolandJones
Hi
@Dessanya1
Just to explain the error, it sounds like it's trying to take the first row as the header row - so the repeating values are causing problems as it's a strict rule in RapidMiner that you can't have columns with the same name. As mentioned above, you can either use the import wizard, or in the parameters pane untick the use header row option.
Hope this helps. Best,
Roland
