<?xml version="1.0" encoding="UTF-8"?><process version="10.3.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="10.3.000" expanded="true" name="Process" origin="GENERATED_TUTORIAL">
<process expanded="true">
<operator activated="true" breakpoints="after" class="subprocess" compatibility="10.3.000" expanded="true" height="82" name="Subprocess" origin="GENERATED_TUTORIAL" width="90" x="313" y="30">
<operator activated="true" class="generate_nominal_data" compatibility="10.3.000" expanded="true" height="68" name="Generate Nominal Data" origin="GENERATED_TUTORIAL" width="90" x="380" y="30">
<parameter key="number_examples" value="100"/>
<parameter key="number_of_attributes" value="2"/>
<parameter key="number_of_values" value="5"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
<operator activated="true" class="set_data" compatibility="10.3.000" expanded="true" height="82" name="Set Data" origin="GENERATED_TUTORIAL" width="90" x="514" y="30">
<parameter key="example_index" value="1"/>
<parameter key="count_backwards" value="false"/>
<parameter key="attribute_name" value="label"/>
<parameter key="value" value="new_label"/>
<list key="additional_values">
<parameter key="att1" value="new_name1"/>
<parameter key="att2" value="new_name2"/>
</list>
<connect from_op="Generate Nominal Data" from_port="output" to_op="Set Data" to_port="example set input"/>
<connect from_op="Set Data" from_port="example set output" to_port="out 1"/>
</process>
<operator activated="true" breakpoints="after" class="blending:rename_by_example_values" compatibility="10.3.000" expanded="true" height="82" name="Rename by Example Values" origin="GENERATED_TUTORIAL" width="90" x="514" y="30">
<parameter key="row_number" value="1"/>
<operator activated="true" class="blending:set_role" compatibility="10.3.000" expanded="true" height="82" name="Set Role" width="90" x="715" y="34">
<list key="set_roles"/>
<connect from_op="Subprocess" from_port="out 1" to_op="Rename by Example Values" to_port="example set input"/>
<connect from_op="Rename by Example Values" from_port="example set output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_port="result 1"/>
</process>
</process>
The above process is a process that additionally connects 'set role' to the 'Rename by Example Values' operator's tutorial.
'Rename by Example Values' changes the column name, but 'set role' does not recognize the changed name.
Am I doing something wrong? Please confirm
thank you
