<?xml version="1.0" encoding="UTF-8"?><process version="10.2.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="10.2.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="UTF-8"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="10.2.000" expanded="true" height="68" name="Retrieve dataset" width="90" x="45" y="34"> <parameter key="repository_entry" value="//Local Repository/Demos/Full-Iris"/> </operator> <operator activated="true" class="set_macro" compatibility="10.2.000" expanded="true" height="82" name="Set Macro" width="90" x="179" y="34"> <parameter key="macro" value="counter"/> <parameter key="value" value="1"/> </operator> <operator activated="true" class="loop_labels" compatibility="10.2.000" expanded="true" height="82" name="Loop Labels" width="90" x="313" y="34"> <process expanded="true"> <operator activated="true" class="write_excel" compatibility="10.2.000" expanded="true" height="103" name="Write Excel" width="90" x="112" y="34"> <parameter key="excel_file" value="C:/Users/rjones/Downloads/test-%{counter}.xlsx"/> <parameter key="file_format" value="xlsx"/> <enumeration key="sheet_names"/> <parameter key="sheet_name" value="RapidMiner Data"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="number_format" value="#.0"/> <parameter key="encoding" value="UTF-8"/> </operator> <operator activated="true" class="generate_macro" compatibility="10.2.000" expanded="true" height="82" name="Generate Macro" width="90" x="313" y="85"> <list key="function_descriptions"> <parameter key="counter" value="eval(%{counter})+1"/> </list> </operator> <connect from_port="example set" to_op="Write Excel" to_port="input"/> <connect from_op="Write Excel" from_port="through" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_port="out 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve dataset" from_port="output" to_op="Set Macro" to_port="through 1"/> <connect from_op="Set Macro" from_port="through 1" to_op="Loop Labels" to_port="example set"/> <connect from_op="Loop Labels" from_port="out 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
