<?xml version="1.0" encoding="UTF-8"?><process version="10.2.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="10.2.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="UTF-8"/> <process expanded="true"> <operator activated="true" class="utility:create_exampleset" compatibility="10.2.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="45" y="34"> <parameter key="generator_type" value="comma separated text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="input_csv_text" value="att1; att2 15602;[{'id': 1495, 'name': 'fishing'}, {'id': 12392, 'name': 'best friend'}, {'id': 179431, 'name': 'duringcreditsstinger'}, {'id': 208510, 'name': 'old men'}]"/> <parameter key="column_separator" value=";"/> <parameter key="parse_all_as_nominal" value="true"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="blending:set_role" compatibility="10.2.000" expanded="true" height="82" name="Set Role" width="90" x="179" y="34"> <list key="set_roles"> <parameter key="att1" value="id"/> </list> </operator> <operator activated="true" class="replace" compatibility="10.2.000" expanded="true" height="82" name="Remove special characters" width="90" x="313" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="att2"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="replace_what" value="[\[\]\{\}\s\']"/> <parameter key="replace_by" value=""/> </operator> <operator activated="true" class="split" compatibility="10.2.000" expanded="true" height="82" name="Split" width="90" x="447" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="split_pattern" value=","/> <parameter key="split_mode" value="ordered_split"/> </operator> <operator activated="true" class="blending:select_attributes" compatibility="10.2.000" expanded="true" height="82" name="Select Attributes" width="90" x="581" y="34"> <parameter key="type" value="include attributes"/> <parameter key="attribute_filter_type" value="a subset"/> <parameter key="select_attribute" value=""/> <parameter key="select_subset" value="att2_2␞att2_4␞att2_6␞att2_8"/> <parameter key="also_apply_to_special_attributes_(id,_label..)" value="false"/> </operator> <operator activated="true" class="replace" compatibility="10.2.000" expanded="true" height="82" name="Remove name:" width="90" x="715" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="replace_what" value="name:"/> </operator> <connect from_op="Create ExampleSet" from_port="output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Remove special characters" to_port="example set input"/> <connect from_op="Remove special characters" from_port="example set output" to_op="Split" to_port="example set input"/> <connect from_op="Split" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Remove name:" to_port="example set input"/> <connect from_op="Remove name:" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
