I have a collection of examples sets. They all have the same number of observations and the same ids, but differ in the variables other than the iD. How do I merge them into a single example set? I have tried (unsuccessfully) to use joins. I'm sure there must be a trivial solution (for the experts on this forum), but it completely eludes me. Here's an initial process with the Iris dataset.
<?xml version="1.0" encoding="UTF-8"?><process version="10.1.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="10.1.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="10.1.001" expanded="true" height="68" name="Retrieve Iris" width="90" x="179" y="136">
<parameter key="repository_entry" value="//Samples/data/Iris"/>
<operator activated="true" class="generate_id" compatibility="10.1.001" expanded="true" height="82" name="Generate ID" width="90" x="313" y="136">
<parameter key="create_nominal_ids" value="false"/>
<parameter key="offset" value="0"/>
<operator activated="true" class="blending:select_attributes" compatibility="10.1.001" expanded="true" height="82" name="Select Attributes" width="90" x="447" y="136">
<parameter key="type" value="include attributes"/>
<parameter key="attribute_filter_type" value="a subset"/>
<parameter key="select_attribute" value=""/>
<parameter key="select_subset" value="id␞a1"/>
<parameter key="also_apply_to_special_attributes_(id,_label..)" value="true"/>
<operator activated="true" class="retrieve" compatibility="10.1.001" expanded="true" height="68" name="Retrieve Iris (2)" width="90" x="179" y="289">
<operator activated="true" class="generate_id" compatibility="10.1.001" expanded="true" height="82" name="Generate ID (2)" width="90" x="313" y="289">
<operator activated="true" class="blending:select_attributes" compatibility="10.1.001" expanded="true" height="82" name="Select Attributes (2)" width="90" x="447" y="289">
<parameter key="select_subset" value="id␞a2"/>
<operator activated="true" class="retrieve" compatibility="10.1.001" expanded="true" height="68" name="Retrieve Iris (3)" width="90" x="179" y="442">
<operator activated="true" class="generate_id" compatibility="10.1.001" expanded="true" height="82" name="Generate ID (3)" width="90" x="313" y="442">
<operator activated="true" class="blending:select_attributes" compatibility="10.1.001" expanded="true" height="82" name="Select Attributes (3)" width="90" x="447" y="442">
<parameter key="select_subset" value="id␞a3"/>
<operator activated="true" class="retrieve" compatibility="10.1.001" expanded="true" height="68" name="Retrieve Iris (4)" width="90" x="179" y="544">
<operator activated="true" class="generate_id" compatibility="10.1.001" expanded="true" height="82" name="Generate ID (4)" width="90" x="313" y="544">
<operator activated="true" class="blending:select_attributes" compatibility="10.1.001" expanded="true" height="82" name="Select Attributes (4)" width="90" x="447" y="544">
<parameter key="select_subset" value="id␞a4"/>
<operator activated="true" class="collect" compatibility="10.1.001" expanded="true" height="145" name="Collect" width="90" x="715" y="289">
<parameter key="unfold" value="false"/>
<connect from_op="Retrieve Iris" from_port="output" to_op="Generate ID" to_port="example set input"/>
<connect from_op="Generate ID" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Collect" to_port="input 1"/>
<connect from_op="Retrieve Iris (2)" from_port="output" to_op="Generate ID (2)" to_port="example set input"/>
<connect from_op="Generate ID (2)" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/>
<connect from_op="Select Attributes (2)" from_port="example set output" to_op="Collect" to_port="input 2"/>
<connect from_op="Retrieve Iris (3)" from_port="output" to_op="Generate ID (3)" to_port="example set input"/>
<connect from_op="Generate ID (3)" from_port="example set output" to_op="Select Attributes (3)" to_port="example set input"/>
<connect from_op="Select Attributes (3)" from_port="example set output" to_op="Collect" to_port="input 3"/>
<connect from_op="Retrieve Iris (4)" from_port="output" to_op="Generate ID (4)" to_port="example set input"/>
<connect from_op="Generate ID (4)" from_port="example set output" to_op="Select Attributes (4)" to_port="example set input"/>
<connect from_op="Select Attributes (4)" from_port="example set output" to_op="Collect" to_port="input 4"/>
<connect from_op="Collect" from_port="collection" to_port="result 1"/>
</process>
</process>
