RapidProM error when executing Conformance checking
lutsa21
lutsa21 New Altair Community Member
I installed RapidProM and most operators work fine. However, when I try to execute the conformance checking operator I get the following error. I'm using MacOS.
Process failed: class org.rapidprom.operators.conformance.ConformanceAnalysisOperator tried to access private method 'void com.google.common.util.concurrent.SimpleTimeLimiter.<init>(java.util.concurrent.ExecutorService)' (org.rapidprom.operators.conformance.ConformanceAnalysisOperator is in unnamed module of loader com.rapidminer.tools.plugin.PluginClassLoader @455824ad; com.google.common.util.concurrent.SimpleTimeLimiter is in unnamed module of loader 'app')
Please help! thank you
  • holymoly24
    holymoly24 New Altair Community Member
    same issue :)
  • jwpfau
    jwpfau
    RapidProM is a third party extension. The used method was deprecated  and later made private in 2017.
    The Extension would have to be rebuild against RapidMiner 10.
    For this issue it should be enough to use the "new" static SimpleTimeLimiter.create(ExecutorService) method instead of new SimpleTimeLimiter(ExecutorService). But there might be other things that also fail.
    Greetings,
    Jonas
