Dear All,
I have a dataset from Kaggle (updated). I loaded it into RapidMiner Studio and I would like to prepare a model with Auto Model function. I tried all of the opportunities but these showed the following error:
Error
Process: Support Vector Machine
The attribute A) was already present in the example set.
Details
com.rapidminer.example.SimpleAttributes.rename(SimpleAttributes.java:183)
com.rapidminer.example.table.AbstractAttribute.setName(AbstractAttribute.java:208)
com.rapidminer.operator.preprocessing.filter.ChangeAttributeNamesReplace.apply(ChangeAttributeNamesReplace.java:107)
com.rapidminer.operator.AbstractExampleSetProcessing.doWork(AbstractExampleSetProcessing.java:138)
com.rapidminer.operator.Operator.execute(Operator.java:1023)
com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:77)
com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:805)
com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:800)
java.security.AccessController.doPrivileged(Native
Method)
com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:800)
com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:423)
com.rapidminer.operator.SimpleOperatorChain.doWork(SimpleOperatorChain.java:99)
Method)
Method)
com.rapidminer.Process.executeRoot(Process.java:1477)
com.rapidminer.Process.lambda$executeRootInPool$5(Process.java:1453)
com.rapidminer.studio.concurrency.internal.AbstractConcurrencyContext$AdaptedCallable.exec(AbstractConcurrencyContext.java:362)
java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:289)
java.util.concurrent.ForkJoinPool$WorkQueue.runTask(ForkJoinPool.java:1056)
java.util.concurrent.ForkJoinPool.runWorker(ForkJoinPool.java:1692)
java.util.concurrent.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:175)
Could you help me to fix it?
