Setting the whole matrix dataset as a label
Let's say you have two-time series datasets, the first dataset has five explanatory variables, and the other one is a dependent dataset with about 1000 variables, each representing an individual cell. So how do you set the whole dependent dataset as a label for prediction or regression analysis?
If not possible, is it possible to loop the whole dataset and perform predictions for each cell?
