Wrong data applying
User: "NgocNguyen2001"
New Altair Community Member
Updated by Jocelyn
Hi guys, I've been applying some algorithms like Naive Bayes, k-NN, and Decision Tree, the process works well, but the preprocessing operation with the Remove Duplicate method keeps on returning this result, no matter which attributes I changed.
Any support would be perfect! Thanks so much!
1 - 3 of 31
    User: "Caperez"
    Hi @NgocNguyen2001
    If you select subset or single in "attribute filter type" you need to provide the attributes that you want to consider
    Is that your case?
    Best
    OP
    Yes, I have set it to the no missing values but it still doesn't work at all
    User: "Caperez"
    Hi @NgocNguyen2001
    please check that you haven't missing values in any example in your attributes.
    If you have missing values in any example of your attributes this option will ignore all of them.
    Best,
    Cesar
