SimLab CFD Mesh function is invalid
Hi Support,
I'd like to use the CFD Mesh function. After pressing "apply", a progress bar will appear on the screen, but in fact there is no progress in the mesh division. (Please refer to the screenshot below.) I have tried reinstalling the software, and the function works at first, but it'll finally be invalid again. The SimLab version is 2022.3.1. I will be grateful if you can provide a solution.
Gary
Hello Gary,
The progress bar in SimLab will not show how much it has completed. Currently, the progress is useful only to kill the process.
Are you not able to generate the CFD mesh for your model? If so, please let me know the error you are getting while generating CFD mesh. We will check and get back you.
Thanks & Regards,
Santhoshkumar
Hi Santhoshkumar,
Thanks for your prompt reply. There's no error message, and I check the task manager after pressing "Apply", the hypermesh program doesn't look like it's doing calculations. The only message I get is "Error:: BF Mesh failed" after I terminate the calculation.
Gary
Hi Santhoshkumar,
Gary
Hello Gary,
Is it possible to share the model? Will check and get back.
Thanks & Regards,
Santhoshkumar
Hello Gary,
Thanks & Regards,
Santhoshkumar
Hi Santhoshkumar,
Here is the model.
Thanks and regards,
Gary
Hello Gary,
Thanks & Regards,
Santhoshkumar
