Add new column if then in existing column
syazwaan
I have a dataset something like this:
I want to make a new column if data in column_1 is start with a number and ends with a letter and return 'Complete' or 'Incomplete' in a new column.
Expected output:
Thank you.
RegEx
BalazsBaranyRM
Hi!
You could use Generate Attributes for this.
Determining if a text starts with a number and ends with a letter is the domain of regular expressions. These are usable in different places in RapidMiner, there's even a nice regular expression editor for example in the Replace operator.
In Generate Attributes, you would use the
if()
and
matches()
functions. Here's an example for your use case:
if(matches(column_1, "^[0-9]+.+[a-zA-Z]$"), "Complete", "Incomplete")
The regexp is a bit terrifying in the beginning but it is simple to explain.
^ beginning of the string
[0-9] character class: Numbers from 0 to 9
+ at least one of the element before (the character class)
.+ anything
[a-zA-Z] letters (if you need additional characters, enter them after the Z)
$ end of the string
So the logic goes: If the value of column_1 matches the regular expression, the
if
function returns the second argument (Complete), else the third one.
Balázs
BalazsBaranyRM
Hi!
if()
and
matches()
.+ anything
$ end of the string
if
Balázs
Telcontar120
You could also use the Generate Copy operator and then use Generate Attributes with PREFIX and SUFFIX functions if you simply want to keep separate attributes for both the first and last character of the raw data (this may be helpful depending on what else you want to do with it or if those codes have some meaning).
