My rapidminer error and I don't know the error because of what? please help me
Jeremy31
New Altair Community Member
# There is insufficient memory for the Java Runtime Environment to continue.
# Native memory allocation (mmap) failed to map 536870912 bytes for Failed to commit area from 0x0000000724000000 to 0x0000000744000000 of length 536870912.
# Possible reasons:
# The system is out of physical RAM or swap space
# The process is running with CompressedOops enabled, and the Java Heap may be blocking the growth of the native heap
# Possible solutions:
# Reduce memory load on the system
# Increase physical memory or swap space
# Check if swap backing store is full
# Decrease Java heap size (-Xmx/-Xms)
# Decrease number of Java threads
# Decrease Java thread stack sizes (-Xss)
# Set larger code cache with -XX:ReservedCodeCacheSize=
# JVM is running with Zero Based Compressed Oops mode in which the Java heap is
# placed in the first 32GB address space. The Java Heap base address is the
# maximum limit for the native heap growth. Please use -XX:HeapBaseMinAddress
# to set the Java Heap base and to place the Java Heap above 32GB virtual address.
# This output file may be truncated or incomplete.
# Out of Memory Error (os_windows.cpp:3440), pid=6328, tid=0x00000000000006c8
# JRE version: OpenJDK Runtime Environment (8.0_265-b01) (build 1.8.0_265-b01)
# Java VM: OpenJDK 64-Bit Server VM (25.265-b01 mixed mode windows-amd64 compressed oops)
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
--------------- T H R E A D ---------------
Current thread (0x000001feffca1000): VMThread [stack: 0x0000008e05500000,0x0000008e05600000] [id=1736]
Stack: [0x0000008e05500000,0x0000008e05600000]
[error occurred during error reporting (printing stack bounds), id 0xc0000005]
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
VM_Operation (0x0000008e04dfd7c0): G1IncCollectionPause, mode: safepoint, requested by thread 0x000001fefb483000
--------------- P R O C E S S ---------------
