Hello everyone!
I'm new to text mining. A very simple task turned out to be an unsolvable one for me
I have 50 pdf documents in English. From there I need to extract the sentences which contain at least one modal verb (for further analysis).
Inside the "process documents from files" operator I created "tokenize" (linguistic sentences) and "filter tokens by content" operators. In "filter tokens by content" I wrote the verbs divided by a vertical line with no spaces, but it doesn't work, the results are empty. It works fine if I write only one verb, but if I write many verbs with a vertical line, it doesn't. I tried all the conditions of the operator, none of them make it work.
I will be very grateful for help!
Here is my process:
<process version="5.3.015">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="text:process_document_from_file" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Files" width="90" x="313" y="120">
<list key="text_directories">
<parameter key="pdf" value="D:\Все\УЧЁБА\ВКР\Материал\Оригинальные"/>
</list>
<parameter key="file_pattern" value="*pdf"/>
<operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize" width="90" x="179" y="120">
<parameter key="mode" value="linguistic sentences"/>
<operator activated="true" class="text:filter_tokens_by_content" compatibility="5.3.002" expanded="true" height="60" name="Filter Tokens (by Content)" width="90" x="380" y="120">
<parameter key="condition" value="matches"/>
<parameter key="string" value="can|could|may|might"/>
<parameter key="regular_expression" value="can|could|may|might"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Tokens (by Content)" to_port="document"/>
<connect from_op="Filter Tokens (by Content)" from_port="document" to_port="document 1"/>
</process>
<connect from_op="Process Documents from Files" from_port="example set" to_port="result 1"/>
<connect from_op="Process Documents from Files" from_port="word list" to_port="result 2"/>
</process>
</process>
