How to remove duplicate data
jmphillips
Hello community: I have a problem withe duplicate data, this is an example:
Col 1 Col 2
39-2021
49-2021
49-2021
39-2021
so I want to remove one of those rows.
Help please, you are my only hope.....
Similarity
Results View
Duplicates
BalazsBaranyRM
Hi
@jmphillips
this sounds like a good use case for De-Pivot, removing the duplicates, and Pivot again.
De-Pivot will put all values into subsequent rows and keep the information about the column name (Col 1, Col 2) in another column. You would then remove the duplicates according to your rules and use Pivot to build the original data structure again.
Be careful to remove entire "rows" (original rows, which are multiple rows after the De-Pivot). If you don't do that, you will have missing data upon pivoting again.
Balázs
jmphillips
Thanks, Balazs, but I dont know how to use those operators....
jmphillips
FIRST_ID
SECOND_ID
SIMILARITY
24260-2016
24413-2016
1.0
24413-2016
24260-2016
1.0***
22055-2016
22056-2016
1.0
22056-2016
22055-2016
1.0
22057-2016
22058-2016
1.0
22057-2016
22060-2016
1.0
22057-2016
22059-2016
1.0
22058-2016
22057-2016
1.0
22058-2016
22060-2016
1.0
22058-2016
22059-2016
1.0
22060-2016
22057-2016
1.0
22060-2016
22058-2016
1.0
22060-2016
22059-2016
1.0
22059-2016
22057-2016
1.0
22059-2016
22058-2016
1.0
22059-2016
22060-2016
1.0
If I de pivot all SECOND_ID are goit to a new collum, with the FIRST_ID data, so if I then remove duplicates Im going to loose data, the problem si that I want to eliminate for example *** 24413-2016 24260-2016 because I have 24260-2016 24413-2016 the first and the second Id in the case are the same but inverted.
BalazsBaranyRM
another approach would be duplicating the data with Multiply and then joining with Left Outer join on FIRST_ID = SECOND_ID *and* SECOND_ID = FIRST_ID. You could then decide which matches to remove.
Balázs
jmphillips
Balazs, sorry dont know how to do it... can you sent me the box and parameter to use? Please.
Regards.
frederic_gomer_
HI,
jmphillips
You can try this process
Attach file : How_to_remove_duplicate_data.rmp
jmphillips
Thanks Frederic for the answer but, row one is asociated at first and second columm
the second row is the same values but inverted, so I want to remove the complete second row.
Regards.
FIRST_ID
SECOND_ID
SIMILARITY
24260-2016
24413-2016
1.0
24413-2016
24260-2016
1.0
