Process Failed - Holt-Winters is not ... trained before
kose
Hi all,
I am pretty new at using rapidminer and I have a question which may have a very simple solution. When I run a pre-made process, I am getting this error:
"Process failed. Holt-Winters is not trained on a time series Run initializeSmoothing(List<Double) values before."
prnt.sc/1l476bd
The process is working on the computer who sent me this process even though we follow every step exactly the same. I have installed Forecasting, Operator Toolbox, Holt-Winters Filtering extensions.
Thanks in advance!
Errors
tftemme
Hi
@kose
You probably found a bug, which rarely occurs and is caused by specific structure of your input data on which you want to train the Holt-Winters model on.
We will work on the bug and fix it in a future version of RM Studio.
For now, you can check if you input data set contains one or more small period of 0 values. If the number of consecutive zeros in your data set is larger than the period, the bug is triggered. In this case please try a larger period for the Holt-Winters.
Otherwise it also can be that you have every x value a zero, you have selected multiplicative for the seasonality model and you period is x (for example you have daily data but always 0 for the sunday (so every 7.th value) and you have 7 as the period. Than the error can be triggered as well. Than you can change to additive seasonality model for now.
Hopes this helps,
Best regards,
Fabian
kose
I am still having this problem. I also tried on another computer and I got the same error. I'll be thankful for any help!
MartinLiebig
this is something I never saw before. Any chance you can share the data and the process so that we can have a look?
Cheers,
Martin
tftemme
Hi
@kose
Hopes this helps,
Best regards,
Fabian
kose
Hi
@mschmitz
and
@tftemme
I will try it again with these instructions. If I find a solution, I will let you know as soon as possible. Otherwise, I can share the data and the process.
Thank you so much for your help.
Kose
MartinLiebig
Hi
@kose
thanks for the offer. I think we were able to reproduce the error on test data.
Please keep us posted on your progress.
Cheers,
Martin
kose
Hi
@mschmitz
@tftemme
Yes, it works! As you said, the problem was about the data, if the input data has a period full of 0's, then it gives this error. I appreciate your help so much.
Kose
