Write database error - unique constraint vs batch mode
I'm getting some error with a Write Database operator. I usually write data using append mode in a table in an Oracle Database which as a unique constraint on some attributes. The connection with the database is not direct but I rather connect to a Denodo "database" which automatically push the data to the original database.
I've observed that if I write data in Append bond with a batch value smaller than the table size I get the following error:
There was an error during a batch insertion: ORA-00001: unique constraint (<constraint_name>) violated
On the other hand, if I set the batch to 0 the operation is rather slow. Have you never faced something similar? It is not clear if the problem is related to some back-end operator of the Write Database operator or if it is due to Denodo connection.
Thanks
R
