Weird error with Project: entry does not exist (even if it is)
User: "radema"
New Altair Community Member
Updated by Jocelyn
I'm stuck due to an error I get when I execute a process on AI Hub from a repository Project.
I try to retrieve a connection which is located in the repository and I get the following error message on the server:
Cannot retrieve repository data from entry '/Connections/<connection_name>'. Reason: Entry '//<repository_name>/Connections/<connection_name>' does not exist.
Process[1] (Process) subprocess 'Main Process' ==> +- Retrieve[1] (Retrieve)
I have checked what is in the repository and the element is there. Moreover, when I test the connection from the webUI, it works correctly. Do you have any hint about this?
