Now I'm trying to use python learner.
In the documentation, there is;
The behavior of this operator is defined by a Python script which
depending on the operator configuration can be edited by the user.
If the operator is editable, the parameter panel features a set of
buttons at the top of the parameter list that allow to edit the
declaration (e.g., capabilities and parameter types) and the Python
script, as well as to save the configuration as template.
If the operator is not editable, you can check the operator
capabilities to learn more about the inputs supported by the
preconfigured Python script.
And head of Operater Declaration of the tutorial.
Classification and regression in a single Python
Learner
This example shows how to create a single Python Learner, that
supports both classification and regression, and can handle nominal
features. In other words, a Python Leaner that behaves very similar to
RapidMiner's builtin learners.
"name" : "LightGBM",
"editable" : false,
"dropSpecial" : true,
"capabilities" : [ "numerical attributes", "binominal attributes", "polynominal attributes", "polynominal label", "binominal label", "numerical label" ],
"parameters" : [ {
"name" : "boosting_type",
"type" : "category",
"description" : "Types: ‘gbdt’, traditional Gradient Boosting Decision Tree. ‘dart’, Dropouts meet Multiple Additive Regression Trees. ‘goss’, Gradient-based One-Side Sampling. ‘rf’, Random Forest.",
"categories" : [ "gbdt", "dart", "goss", "rf" ],
"value" : "gbdt",
"optional" : true,
"advanced" : false
}I believe "editable" paremeter is to set the operator editable.
"editable" : false,
I have changed the parameter from `false` to `true` but it seems nothing has been changed.
I was wondering how to set the operator editable and what the the parameter "editable" in the declaration.
And also, once the oprator is set to editable false, how can I clear?
