How to use iteration value in a extracted macro to generate another macro?
Himanshu_Pant
I have extracted a macro inside 'loop example'. The loop example is connected to dataset which contains dates. The data set has one attribute called 'Event DateTime_adjusted'. The macro {START_DATE} is extracting 'Event DateTime_adjusted' attribute value. Now I want to generate a macro using this formula :
date_add(%{START_DATE},eval(%{example_index}),DATE_UNIT_DAY).
But it is throwing an error: The function date_add must have an argument of type 'date'
MartinLiebig
@Himanshu_Pant
attached is the fixed process. I hope it does what you want. The challenge you had, was the default time format we use for strings. I just used date_str_custom and Extract Macro (format) to use another one.
Best,
Martin
<?xml version="1.0" encoding="UTF-8"?><process version="9.9.002">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.9.002" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="utility:create_exampleset" compatibility="9.9.002" expanded="true" height="68" name="Create ExampleSet (2)" width="90" x="45" y="85">
<parameter key="generator_type" value="comma separated text"/>
<parameter key="number_of_examples" value="100"/>
<parameter key="use_stepsize" value="false"/>
<list key="function_descriptions"/>
<parameter key="add_id_attribute" value="false"/>
<list key="numeric_series_configuration"/>
<list key="date_series_configuration"/>
<list key="date_series_configuration (interval)"/>
<parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="input_csv_text" value="Event DateTime 2019-04-10T18:45:00.000Z 2019-04-21T17:45:00.000Z"/>
<parameter key="column_separator" value=","/>
<parameter key="parse_all_as_nominal" value="false"/>
<parameter key="decimal_point_character" value="."/>
<parameter key="trim_attribute_names" value="true"/>
<operator activated="true" class="nominal_to_date" compatibility="9.9.002" expanded="true" height="82" name="Nominal to Date (3)" width="90" x="179" y="85">
<parameter key="attribute_name" value="Event DateTime"/>
<parameter key="date_type" value="date_time"/>
<parameter key="date_format" value="yyyy-MM-dd'T'HH:mm:ss.SSS'Z'"/>
<parameter key="locale" value="English (United States)"/>
<parameter key="keep_old_attribute" value="true"/>
<operator activated="true" class="set_macros" compatibility="9.9.002" expanded="true" height="68" name="Set Macros" width="90" x="179" y="289">
<list key="macros">
<parameter key="wisi" value="2"/>
<parameter key="sile" value="5"/>
<parameter key="jum" value="1"/>
</list>
<operator activated="true" class="generate_attributes" compatibility="9.9.002" expanded="true" height="82" name="Generate Attributes (3)" width="90" x="313" y="85">
<parameter key="Event DateTime_adjusted" value="date_add([Event DateTime],-eval(%{sile}),DATE_UNIT_DAY)"/>
</list>
<parameter key="keep_all" value="true"/>
<operator activated="false" class="date_to_nominal" compatibility="9.9.002" expanded="true" height="82" name="Date to Nominal" width="90" x="447" y="289">
<parameter key="attribute_name" value="Event DateTime_adjusted"/>
<parameter key="keep_old_attribute" value="false"/>
<operator activated="true" class="loop_examples" compatibility="9.9.002" expanded="true" height="103" name="Loop Examples" width="90" x="581" y="85">
<parameter key="iteration_macro" value="example_index"/>
<operator activated="true" class="operator_toolbox:extract_macro_enhanced" compatibility="3.0.000-SNAPSHOT" expanded="true" height="68" name="Extract Macro (Format)" width="90" x="112" y="34">
<parameter key="macro" value="START_DATE"/>
<parameter key="macro_type" value="data_value"/>
<parameter key="statistics" value="average"/>
<parameter key="example_index" value="%{example_index}"/>
<list key="additional_macros"/>
<parameter key="format_of_numericals" value="#.##"/>
<parameter key="date_format" value="yyyy-MM-dd hh:mm:ss"/>
<operator activated="true" class="generate_macro" compatibility="9.9.002" expanded="true" height="68" name="Generate Macro (7)" width="90" x="112" y="340">
<parameter key="number_of_iteration" value="eval(%{sile})-eval(%{wisi})+1"/>
</list>
<operator activated="true" class="generate_macro" compatibility="9.9.002" expanded="true" height="68" name="Generate Macro (2)" width="90" x="112" y="238">
<parameter key="start_date_final" value="date_str_custom(date_add(date_parse_custom(%{START_DATE},"yyyy-MM-dd hh:mm:ss"),eval(%{example_index}),DATE_UNIT_DAY),"yyyy-MM-dd hh:mm:ss")"/>
</list>
<operator activated="true" class="concurrency:loop" compatibility="9.9.002" expanded="true" height="82" name="Loop (3)" width="90" x="447" y="34">
<parameter key="number_of_iterations" value="%{number_of_iteration}"/>
<parameter key="iteration_macro" value="iteration"/>
<parameter key="reuse_results" value="false"/>
<parameter key="enable_parallel_execution" value="true"/>
<operator activated="true" class="utility:create_exampleset" compatibility="9.9.002" expanded="true" height="68" name="Create ExampleSet" width="90" x="380" y="136">
<parameter key="generator_type" value="date series"/>
<parameter key="number_of_examples" value="192"/>
<parameter key="use_stepsize" value="true"/>
<list key="date_series_configuration (interval)">
<parameter key="timestamp" value="%{start_date_final}.15.minute"/>
</list>
<connect from_op="Create ExampleSet" from_port="output" to_port="output 1"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
<operator activated="true" class="generate_macro" compatibility="9.9.002" expanded="true" height="68" name="Generate Macro" width="90" x="112" y="136">
<parameter key="days" value="96 *(eval(%{wisi}) + 1) + %{example_index}"/>
</list>
<operator activated="false" class="extract_macro" compatibility="9.9.002" expanded="true" height="68" name="Extract Macro" width="90" x="246" y="34">
<connect from_port="example set" to_op="Extract Macro (Format)" to_port="example set"/>
<connect from_op="Loop (3)" from_port="output 1" to_port="output 1"/>
<portSpacing port="sink_example set" spacing="0"/>
</process>
<operator activated="true" class="append" compatibility="9.9.002" expanded="true" height="82" name="Append" width="90" x="715" y="85">
<parameter key="datamanagement" value="double_array"/>
<parameter key="data_management" value="auto"/>
<parameter key="merge_type" value="all"/>
<connect from_op="Create ExampleSet (2)" from_port="output" to_op="Nominal to Date (3)" to_port="example set input"/>
<connect from_op="Nominal to Date (3)" from_port="example set output" to_op="Generate Attributes (3)" to_port="example set input"/>
<connect from_op="Generate Attributes (3)" from_port="example set output" to_op="Loop Examples" to_port="example set"/>
<connect from_op="Loop Examples" from_port="output 1" to_op="Append" to_port="example set 1"/>
<connect from_op="Append" from_port="merged set" to_port="result 1"/>
</process>
</process>
Marco_Barradas
Hi
@Himanshu_Pant
You'll need to date parse the macro date you are using.
date_add(date_parse_custom(%{START_DATE},"yyy-MM-dd hh:mm:ss"),eval(%{example_index}),DATE_UNIT_DAY)
Just adjust your date string to your format.
Himanshu_Pant
This method worked. However, while using this macro in 'Create Example Set" getting wrong Date format error.
MartinLiebig
likely you need to adjust the date format setting? or maybe its because Marco had a spelling error with only 3 y's.
Best,
Martin
Himanshu_Pant
Hi
@mschmitz
Adding the process. Please have a look.
process.txt
MartinLiebig
can you try Extract Macro (Format) from operator toolbox? It allows you to specify the date format manually.
Best,
Martin
Himanshu_Pant
Yes, but in extract macro I can't use the formula:
Himanshu_Pant
MarcoBarradas
Please help with this.
MartinLiebig
@Himanshu_Pant
Best,
Martin
<context>
<input/>
<output/>
<macros/>
</context>
<list key="macros">
</list>
</list>
</list>
</list>
</list>
</process>
</list>
</process>
</process>
</process>
