Use of macros as global variables
Himanshu_Pant
Lets say I have used two macros-> macroA and macroB. I want to add a condition: If a value of a column (from a dataset) is greater than 5, increment macroA by 1 and if it is less than 5 increment macroB by 1.
Is it possible? if yes, then how. Please help.
MartinLiebig
Hi
@Himanshu_Pant
I am a bit confused here. Isnt macroA the cumsum of ColumnA? Not sure how you then calculate macroB from there?
Likely this is not a job for macros anyway? Please check the attached process for the cumsum.
Best,
Martin
<?xml version="1.0" encoding="UTF-8"?><process version="9.8.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.8.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="utility:create_exampleset" compatibility="9.8.001" expanded="true" height="68" name="Create ExampleSet" width="90" x="45" y="136">
<parameter key="generator_type" value="comma separated text"/>
<parameter key="number_of_examples" value="100"/>
<parameter key="use_stepsize" value="false"/>
<list key="function_descriptions"/>
<parameter key="add_id_attribute" value="false"/>
<list key="numeric_series_configuration"/>
<list key="date_series_configuration"/>
<list key="date_series_configuration (interval)"/>
<parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="input_csv_text" value="Column A 0 1 0 1 1 1"/>
<parameter key="column_separator" value=","/>
<parameter key="parse_all_as_nominal" value="false"/>
<parameter key="decimal_point_character" value="."/>
<parameter key="trim_attribute_names" value="true"/>
<operator activated="true" class="time_series:integration" compatibility="9.8.001" expanded="true" height="68" name="Integrate" width="90" x="246" y="136">
<parameter key="attribute" value="Column A"/>
<parameter key="value_type" value="numeric"/>
<parameter key="except_value_type" value="real"/>
<parameter key="block_type" value="value_series"/>
<parameter key="except_block_type" value="value_series_end"/>
<parameter key="has_indices" value="false"/>
<parameter key="indices_attribute" value=""/>
<parameter key="overwrite_attributes" value="false"/>
<parameter key="new_attributes_postfix" value="_integrated"/>
<parameter key="skip_invalid_values" value="true"/>
<parameter key="integration_method" value="cumulative sum"/>
<connect from_op="Create ExampleSet" from_port="output" to_op="Integrate" to_port="example set"/>
<connect from_op="Integrate" from_port="example set" to_port="result 1"/>
</process>
</process>
MartinLiebig
Hi
@Himanshu_Pant
yes it is. You first extract the value of the column using Extract Macro and then you can use Generate Macro to do the conditional increment.
Best,
Martin
Himanshu_Pant
I want to keep adding the value:
lets say I have a column
Column A
1
1
1
1
I want the output
macroA
macroB
1
1
1
1
2
2
2
3
2
4
2
MartinLiebig
Hi
@Himanshu_Pant
Best,
Martin
<context>
<input/>
<output/>
<macros/>
</context>
</process>
</process>
Himanshu_Pant
Can you please share rmp file?
Himanshu_Pant
@mschmitz
no need. Thank you.
