Dear RapidMiner Community,
I am struggeling to figure out , how to reduce my target attribute (Label) to 3 values.
The target attribute is identified as integer and contains following numbers: 1,2,3,4,5,6,7,8,9
The aim is, to transform the numbers into following form:
Low quality (values <6)
Medium quality (values = 6)
High quality (values > 6)
So in the end, it should be displayed for instance low quality instead the numbers (1,2,3,4,5)
This is meant by saying reducing attribute into 3 values (low-, medium-, high quality).
I thing it could be done with Turbo Prep or Transformation Operator but I don´t have a clue.
I would be gratefull to get any tips or tricks
Atilla
