Predict multiple value based on another value
User: "legeithien"
New Altair Community Member
Updated by Jocelyn
Hello guys,
so, i had this data which represents the contents of soil in x-depth and the data only has limited depth. i tried to make model based on contents of soil in x-depth which going to predict those contents of soil arent shown on the depth. e.g contents of soil in 3 m depths and make this data to predict contents of soil in 5m depth
i tried using impute missing values operator to estimate those missing values of contents and using naive bayes, k-NN. i was going to use at least 3 predictions but every time i tried it kept getting errors, so im only using those two for now.
<?xml version="1.0" encoding="UTF-8"?><process version="9.9.000">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="9.9.000" expanded="true" name="Process">
    <process expanded="true">
      <operator activated="true" class="read_excel" compatibility="9.9.000" expanded="true" height="68" name="Read Excel" width="90" x="45" y="34">
        <parameter key="excel_file" value="C:\Users\Avengers\Documents\RapidMiner\Local Repository\fyp\another part1.xlsx"/>
        <parameter key="sheet_selection" value="sheet number"/>
        <parameter key="sheet_number" value="1"/>
        <parameter key="imported_cell_range" value="A1"/>
        <parameter key="first_row_as_names" value="true"/>
        <list key="annotations"/>
        <parameter key="date_format" value=""/>
        <parameter key="time_zone" value="SYSTEM"/>
        <parameter key="locale" value="English (United States)"/>
        <parameter key="read_all_values_as_polynominal" value="false"/>
          <parameter key="0" value="Depth (m).true.real.attribute"/>
          <parameter key="1" value="Gravel.true.integer.attribute"/>
          <parameter key="2" value="Sand.true.real.attribute"/>
          <parameter key="3" value="Silt.true.real.attribute"/>
          <parameter key="4" value="Clay.true.integer.attribute"/>
          <parameter key="5" value="LL.true.integer.attribute"/>
          <parameter key="6" value="PL.true.integer.attribute"/>
          <parameter key="7" value="PI.true.integer.attribute"/>
          <parameter key="8" value="Moisture Content (%).true.real.attribute"/>
          <parameter key="9" value="Bulk Density (Mg/m3).true.real.attribute"/>
          <parameter key="10" value="Dry Density (Mg/m3).true.real.attribute"/>
          <parameter key="11" value="Specific Gravity.true.real.attribute"/>
          <parameter key="12" value="SPT (N).true.integer.attribute"/>
          <parameter key="13" value="Type of Soil.true.polynominal.attribute"/>
          <parameter key="14" value="Soil Condition.true.polynominal.attribute"/>
          <parameter key="15" value="Resistivity (Ohm\.m).true.real.attribute"/>
          <parameter key="16" value="Seismic, Vp (km/s).true.real.attribute"/>
        </list>
        <parameter key="read_not_matching_values_as_missings" value="true"/>
      <operator activated="true" class="subprocess" compatibility="9.9.000" expanded="true" height="82" name="Subprocess" width="90" x="179" y="34">
          <operator activated="true" class="select_attributes" compatibility="9.9.000" expanded="true" height="82" name="Select Attributes" width="90" x="45" y="34">
            <parameter key="attribute_filter_type" value="all"/>
            <parameter key="attribute" value=""/>
          <operator activated="true" class="set_role" compatibility="9.9.000" expanded="true" height="82" name="Set Role" width="90" x="179" y="34">
            <parameter key="attribute_name" value="Type of Soil"/>
            <parameter key="target_role" value="prediction"/>
            <list key="set_additional_roles">
              <parameter key="Type of Soil" value="label"/>
            </list>
          <operator activated="true" class="impute_missing_values" compatibility="9.9.000" expanded="true" height="68" name="Impute Missing Values" width="90" x="313" y="34">
            <parameter key="iterate" value="true"/>
            <parameter key="learn_on_complete_cases" value="true"/>
            <parameter key="order" value="chronological"/>
            <parameter key="sort" value="ascending"/>
            <parameter key="use_local_random_seed" value="false"/>
            <parameter key="local_random_seed" value="1992"/>
              <operator activated="true" class="k_nn" compatibility="9.9.000" expanded="true" height="82" name="k-NN" width="90" x="179" y="34">
                <parameter key="k" value="9"/>
                <parameter key="weighted_vote" value="true"/>
                <parameter key="measure_types" value="MixedMeasures"/>
                <parameter key="mixed_measure" value="MixedEuclideanDistance"/>
                <parameter key="nominal_measure" value="NominalDistance"/>
                <parameter key="numerical_measure" value="EuclideanDistance"/>
                <parameter key="divergence" value="GeneralizedIDivergence"/>
                <parameter key="kernel_type" value="radial"/>
                <parameter key="kernel_gamma" value="1.0"/>
                <parameter key="kernel_sigma1" value="1.0"/>
                <parameter key="kernel_sigma2" value="0.0"/>
                <parameter key="kernel_sigma3" value="2.0"/>
                <parameter key="kernel_degree" value="3.0"/>
                <parameter key="kernel_shift" value="1.0"/>
                <parameter key="kernel_a" value="1.0"/>
                <parameter key="kernel_b" value="0.0"/>
              <connect from_port="example set source" to_op="k-NN" to_port="training set"/>
              <connect from_op="k-NN" from_port="model" to_port="model sink"/>
              <portSpacing port="source_example set source" spacing="0"/>
              <portSpacing port="sink_model sink" spacing="0"/>
            </process>
          <connect from_port="in 1" to_op="Select Attributes" to_port="example set input"/>
          <connect from_op="Select Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/>
          <connect from_op="Set Role" from_port="example set output" to_op="Impute Missing Values" to_port="example set in"/>
          <connect from_op="Impute Missing Values" from_port="example set out" to_port="out 1"/>
          <portSpacing port="source_in 2" spacing="0"/>
        </process>
      <operator activated="true" class="multiply" compatibility="9.9.000" expanded="true" height="103" name="Multiply" width="90" x="313" y="34"/>
      <operator activated="true" class="concurrency:cross_validation" compatibility="9.9.000" expanded="true" height="145" name="k-NN (3)" width="90" x="447" y="187">
        <parameter key="split_on_batch_attribute" value="false"/>
        <parameter key="leave_one_out" value="false"/>
        <parameter key="number_of_folds" value="10"/>
        <parameter key="sampling_type" value="automatic"/>
        <parameter key="enable_parallel_execution" value="true"/>
          <operator activated="true" class="k_nn" compatibility="9.9.000" expanded="true" height="82" name="k-NN (2)" width="90" x="246" y="34">
            <parameter key="k" value="5"/>
          <connect from_port="training set" to_op="k-NN (2)" to_port="training set"/>
          <connect from_op="k-NN (2)" from_port="model" to_port="model"/>
          <portSpacing port="source_training set" spacing="0"/>
        </process>
          <operator activated="true" class="apply_model" compatibility="9.9.000" expanded="true" height="82" name="Apply Model (2)" width="90" x="45" y="34">
            <parameter key="create_view" value="false"/>
          <operator activated="true" class="performance_classification" compatibility="9.9.000" expanded="true" height="82" name="k-NN (4)" width="90" x="179" y="34">
            <parameter key="main_criterion" value="accuracy"/>
            <parameter key="accuracy" value="true"/>
            <parameter key="classification_error" value="false"/>
            <parameter key="kappa" value="true"/>
            <parameter key="weighted_mean_recall" value="false"/>
            <parameter key="weighted_mean_precision" value="false"/>
            <parameter key="spearman_rho" value="false"/>
            <parameter key="kendall_tau" value="false"/>
            <parameter key="absolute_error" value="false"/>
            <parameter key="relative_error" value="false"/>
            <parameter key="relative_error_lenient" value="false"/>
            <parameter key="relative_error_strict" value="false"/>
            <parameter key="normalized_absolute_error" value="false"/>
            <parameter key="root_mean_squared_error" value="true"/>
            <parameter key="root_relative_squared_error" value="false"/>
            <parameter key="squared_error" value="false"/>
            <parameter key="correlation" value="false"/>
            <parameter key="squared_correlation" value="false"/>
            <parameter key="cross-entropy" value="false"/>
            <parameter key="margin" value="true"/>
            <parameter key="soft_margin_loss" value="false"/>
            <parameter key="logistic_loss" value="false"/>
            <parameter key="skip_undefined_labels" value="true"/>
            <parameter key="use_example_weights" value="true"/>
            <list key="class_weights"/>
          <connect from_port="model" to_op="Apply Model (2)" to_port="model"/>
          <connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/>
          <connect from_op="Apply Model (2)" from_port="labelled data" to_op="k-NN (4)" to_port="labelled data"/>
          <connect from_op="k-NN (4)" from_port="performance" to_port="performance 1"/>
          <connect from_op="k-NN (4)" from_port="example set" to_port="test set results"/>
          <portSpacing port="sink_test set results" spacing="0"/>
          <portSpacing port="sink_performance 1" spacing="0"/>
          <portSpacing port="sink_performance 2" spacing="0"/>
        </process>
      <operator activated="true" class="concurrency:cross_validation" compatibility="9.9.000" expanded="true" height="145" name="Naive Buyes" width="90" x="447" y="34">
          <operator activated="true" class="naive_bayes" compatibility="9.9.000" expanded="true" height="82" name="Naive Bayes" width="90" x="246" y="34">
            <parameter key="laplace_correction" value="true"/>
          <connect from_port="training set" to_op="Naive Bayes" to_port="training set"/>
          <connect from_op="Naive Bayes" from_port="model" to_port="model"/>
        </process>
          <operator activated="true" class="apply_model" compatibility="9.9.000" expanded="true" height="82" name="Apply Model" width="90" x="45" y="34">
          <operator activated="true" class="performance_classification" compatibility="9.9.000" expanded="true" height="82" name="Naive Bayes (2)" width="90" x="179" y="34">
          <connect from_port="model" to_op="Apply Model" to_port="model"/>
          <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
          <connect from_op="Apply Model" from_port="labelled data" to_op="Naive Bayes (2)" to_port="labelled data"/>
          <connect from_op="Naive Bayes (2)" from_port="performance" to_port="performance 1"/>
          <connect from_op="Naive Bayes (2)" from_port="example set" to_port="test set results"/>
        </process>
      <connect from_op="Read Excel" from_port="output" to_op="Subprocess" to_port="in 1"/>
      <connect from_op="Subprocess" from_port="out 1" to_op="Multiply" to_port="input"/>
      <connect from_op="Multiply" from_port="output 1" to_op="Naive Buyes" to_port="example set"/>
      <connect from_op="Multiply" from_port="output 2" to_op="k-NN (3)" to_port="example set"/>
      <connect from_op="k-NN (3)" from_port="model" to_port="result 4"/>
      <connect from_op="k-NN (3)" from_port="test result set" to_port="result 6"/>
      <connect from_op="k-NN (3)" from_port="performance 1" to_port="result 5"/>
      <connect from_op="Naive Buyes" from_port="model" to_port="result 1"/>
      <connect from_op="Naive Buyes" from_port="test result set" to_port="result 3"/>
      <connect from_op="Naive Buyes" from_port="performance 1" to_port="result 2"/>
      <portSpacing port="sink_result 5" spacing="0"/>
      <portSpacing port="sink_result 6" spacing="0"/>
      <portSpacing port="sink_result 7" spacing="0"/>
    </process>
</process>
my question is, is it correct? or is there any methods that i could tried to achieve better results?
Thanks in advance!
1 - 3 of 31
    User: "legeithien"
    OP
    please.. anyone?
    I think you should consider to treat this as a time series problem, only that your 'time' is depth.
    Best,
    Martin
    User: "legeithien"
    OP
    Updated by legeithien
    @mschmitz
    will try to do that and give the feedback, thanks for responding it :smile:
    edit: after i look further into it, i dont think it was a suitable method for my data because my data has a time series of "depth" but i need to look for the content of soil on that depth which the depth doesnt have to be a series. what i was looking for is how do i predict the content of that depth
