I want to load "fashion_mnist" dataset from "tensorflow_datasets" and process it with "Deep Learning" extension.
The original "fashion_mnist" data is (60000,(28,28,1),(1)) so, I converted it to the BATCH/ID Tensor by "Execute Python":
import pandas as pd
import numpy as np
import tensorflow as tf
import tensorflow_datasets as tfds
tfds.disable_progress_bar()
image_size = 28
def normalize_img(row):
img = row.image.reshape((image_size,image_size))/255.0
img = np.append(img, [range(image_size)], axis=0)
img = np.append(img, [np.ones(image_size)*row.name], axis=0)
img = np.append(img, [np.ones(image_size)*row.label], axis=0)
row.image = img.T
return row
def preprocess_df(df):
df.image = df.apply(normalize_img, axis=1)
df = pd.DataFrame(np.dstack(df.image.to_numpy()).transpose(2,0,1).reshape(df.shape[0]*image_size,image_size+3))
df.rename(columns={28: 'id', 29:'batch', 30:'label'}, inplace=True)
return df
def rm_main():
dataset, metadata = tfds.load('fashion_mnist', shuffle_files=True, as_supervised=True, with_info=True)
df_train = tfds.as_dataframe(dataset['train'], metadata)
df_test = tfds.as_dataframe(dataset['test'], metadata)
df_train = preprocess_df(df_train)
df_test = preprocess_df(df_test)
return df_train, df_test
First of all, is it correct format?
If I want to set Batch on 32 or 64. How to reshape the tensor with Rapidminer blocks?After that I converted it to Tensor, built model with "Deep Learning (Tensor)", receive the warnings:
WARNING: Couldn't update network in epoch xFinally, when applied it with "Apply Model (Generic)" I receive an error:
Process failed: operator cannot be executed (getColumn() can be called on 2D arrays only).
