I am running a Frequency Response Analysis.
When I change the EIGRL entry to EIGRA, I get following error.
*** ERROR # 3432 ***
Singularity found in construction of constraint equations.
Usually this happens when a dof is defined as slave in more than
one constraints. For inertia relief analysis this problem may be
overcome with SUPORT definitions and/or PARAM,COUPMASS,1.
This error occurs in module 'asmbdrv'.
How this can be resolved ?
