how to pass one attribute values from one process to other process
sgnarkhede2016
I have one process that cotains atttribute "Name" with value "Sachin"
In my other process i want to retrieve records of only "Sachin" that mentioned above
Thanks In Advance
BalazsBaranyRM
there's a detailed video on the Academy about the the different ways to define macros, including the process context.
https://academy.rapidminer.com/learn/video/macros-demo
Balázs
BalazsBaranyRM
Hi!
In xyz.rmp you define the macro "name" with an initial value for testing your process.
Whenever you start the process, the macro will be already defined.
For accessing the parameter in Read Database use "prepare statement" and enter the macro value in the Edit Enumeration window. To refer to the macro value, use this syntax: %{macroName}
Inside the SQL query in Read Database you have to write a question mark to refer to the current value. E. g.:
select *
from mytable
where name = ?
It is also possible to write the macro directly into the SQL statement (where name = '%{macroName}'). However, this can lead to SQL injection or syntax errors, so the prepared statement way is much better.
In abc.rmp you use Execute Process and enter the macro name and value to pass to xyz.rmp.
Balázs
MartinLiebig
likely you want to use Extract Macro and hand it over as a macro.
Best,
Martin
BalazsBaranyRM
you can define macros in the process context. (Activate the Process Context panel in the View menu if you didn't yet.) These macros (text variables) are available as the process parameter interface. In Execute Process you can specify the macros and their values to pass into the subprocess.
Balázs
sgnarkhede2016
Can you please give any example ,not understanding how to use context
BalazsBaranyRM
Balázs
sgnarkhede2016
Thanks,But question still there i need to set macro in other process and acess it other how can that do this.
e.g i have process "abc.rmp" that contains macro "name" with value sachin and i have another process "xyz.rmp" in this process i want use "name" in my read database query
BalazsBaranyRM
Hi!
select *
from mytable
where name = ?
Balázs
