In the first tutorial, called "Getting Started". In section 4/5, after building the simplest of decision trees on the Titanic Training data set, after performing the process, in the tutorial it says
"Great job! Your process should now be complete and deliver a decision
tree model, which explains to you what most of the survivors and most of
the victims had in common."
Actually, I don't see exactly what they are referring to. Just from looking at that tree (see attachment), what do they mean by
what the survivors (or victims) have in common? I don't exactly know how the are reading the tree to say that. Apparently it is obvious since they did not explain it but I don't follow. THANK YOU.
