Hello
I need the fitting tool for estimate Preisach model coefficient in Altair flux for calculating Iron losses, does anyone have it?
best regards
Please find attached the tool to estimate Preisach’s model coefficients, you can run it in Compose 2019.
All the needed information to use this tool is provided in the comments of “main.oml”. You just have to open this script in Compose 2019, update it with your measures and run it.
Best regards.
Hello, Please find attached the tool to estimate Preisach’s model coefficients, you can run it in Compose 2019. All the needed information to use this tool is provided in the comments of “main.oml”. You just have to open this script in Compose 2019, update it with your measures and run it. Best regards.
Thanks for your help.
could you tell me what is the Compose 2019? please.
Compose 2019 is an environment for doing calculations, manipulating and visualizing data (including from CAE simulations or test results), programming and debugging scripts and matrix calculus. It is developed by Altair.
You can download it from Altair Connect (https://connect.altair.com/CP/downloads.html )
Compose 2019 is an environment for doing calculations, manipulating and visualizing data (including from CAE simulations or test results), programming and debugging scripts and matrix calculus. It is developed by Altair. You can download it from Altair Connect (https://connect.altair.com/CP/downloads.html ) Best regards.
thank you
