Hi, is there any way to '' format '' the rapidminer?
GeorgeOik1999
GeorgeOik1999 New Altair Community Member
edited November 5 in Community Q&A
I found my self facing some techical troubles such as : error on creating repository ( valid values ) or '' can not creat a folder ''. I decided that it is better to delete some repositories from my pc folders but I only maanged to make thinks more complicated.
Any feedback will be helpful
George.
Best Answers
  • kayman
    kayman New Altair Community Member
    Answer ✓
    You could always reinstall your rapidminer version if things went really wrong, but normally your repos should not really influence your application as it is in essence just a bunch of text files.
    You could create a new repository and copy the things that still work from old to new and then remove te 'broken' ones, but if you could provide some more details on what is actually wrong we might also be able to fix things instead.
  • MartinLiebig
    MartinLiebig
    Answer ✓
    you can delete the whole .RapidMiner folder in your users folder. All information and stuff is stored there. If you then uninstall RM and install it again you get a blank RM.
    Best,
    Martin
  • kayman
    Answer ✓
  • MartinLiebig
    MartinLiebig
    Answer ✓
    Best,
    Martin
  • GeorgeOik1999
    Thank you for your feedbacks. This capture specifies my problem. Despite the fact that I deleted all my files in the repository folder, I'd like to create a new one refered to rapidminer files, so every time I create a new local repository it will be automatic saved in RM/folder.
  • MartinLiebig
    MartinLiebig
    Can you please try it without a .? . is usually not a good idea in folder names.
    Best,
    Martin
  • GeorgeOik1999
    Still doesn't work. I will try to delete the folder as you mentioned above.
    Thank your for your time.
  • GeorgeOik1999
    Hi again, I did the mistake to delete the rapidminer repositories which were created with my first instalation. Now im working ina folder on desktop but this makes some operators and data not prortable. To exemplify , optimization parameters stacks at 25% and my retrieves has a yellow signal about the sharing process portability. How can i create a repository similar to the first provided by RM studio?
    Thanks in advance.
