Awkward Error on Dictionary Based Sentimental Analysis Process
User: "Melihck"
New Altair Community Member
Updated by Jocelyn
Hi there!
While I am exploring the sentimental analysis I found an XML process from @Benedict_von_Ahmschmitz in the forum.
In their model, they basically put the text into the create_document operator. But in my case, I had to use a dataset because I am working with Tweets. After I made the changes the error the below appears:
My XML is below if anyone can help I would definitely appreciate it🙏.
Also, I would love to see different models with more emotions like "fear" "anger" "joy" etc. instead of positive and negative. Please up me if you know any.
Thanks in advance for your help and for this amazing software.
<?xml version="1.0" encoding="UTF-8"?><process version="9.8.001">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="9.8.001" expanded="true" name="Process">
    <process expanded="true">
      <operator activated="true" class="read_excel" compatibility="9.8.001" expanded="true" height="68" name="Read Excel" width="90" x="112" y="493">
        <parameter key="excel_file" value="D:/Akademik/twitter duygu analizi makale/data-set/EmoLex/NRC-Emotion-Lexicon-v0.92-In105Languages-Nov2017Translations.xlsx"/>
        <parameter key="sheet_selection" value="sheet number"/>
        <parameter key="sheet_number" value="3"/>
        <parameter key="imported_cell_range" value="A1"/>
        <parameter key="first_row_as_names" value="false"/>
        <list key="annotations"/>
        <parameter key="date_format" value=""/>
        <parameter key="time_zone" value="SYSTEM"/>
        <parameter key="locale" value="Turkish"/>
        <parameter key="read_all_values_as_polynominal" value="false"/>
          <parameter key="0" value="A.true.polynominal.attribute"/>
        </list>
        <parameter key="read_not_matching_values_as_missings" value="false"/>
        <parameter key="datamanagement" value="double_array"/>
        <parameter key="data_management" value="auto"/>
        <description align="center" color="transparent" colored="false" width="126">Adapt location please</description>
      <operator activated="true" class="generate_attributes" compatibility="9.8.001" expanded="true" height="82" name="Generate Attributes" width="90" x="246" y="493">
          <parameter key="Score" value="-1"/>
          <parameter key="A" value="lower(A)"/>
        </list>
        <parameter key="keep_all" value="true"/>
      <operator activated="true" class="rename" compatibility="9.8.001" expanded="true" height="82" name="Rename" width="90" x="380" y="493">
        <parameter key="old_name" value="A"/>
        <parameter key="new_name" value="Word"/>
        <list key="rename_additional_attributes"/>
      <operator activated="true" class="read_excel" compatibility="9.8.001" expanded="true" height="68" name="Read Excel (2)" width="90" x="112" y="646">
        <parameter key="sheet_number" value="2"/>
        </list>
      <operator activated="true" class="generate_attributes" compatibility="9.8.001" expanded="true" height="82" name="Generate Attributes (2)" width="90" x="246" y="646">
          <parameter key="Score" value="+1"/>
        </list>
      <operator activated="true" class="rename" compatibility="9.8.001" expanded="true" height="82" name="Rename (2)" width="90" x="380" y="646">
      <operator activated="true" class="append" compatibility="9.8.001" expanded="true" height="103" name="Append" width="90" x="514" y="544">
        <parameter key="merge_type" value="all"/>
      <operator activated="true" class="operator_toolbox:dictionary_sentiment_learner" compatibility="2.8.001" expanded="true" height="103" name="Dictionary-Based Sentiment (Documents)" width="90" x="648" y="544">
        <parameter key="value_attribute" value="Score"/>
        <parameter key="key_attribute" value="Word"/>
        <parameter key="negation_attribute" value=""/>
        <parameter key="negation_window_size" value="1"/>
        <parameter key="negation_strength" value=""/>
        <parameter key="use_symmetric_negation_window" value="false"/>
        <parameter key="use_intensifier" value="false"/>
        <parameter key="intensifier_word" value=""/>
        <parameter key="intensifier_value" value=""/>
        <parameter key="use_symmetric_intensifier_window" value="false"/>
      <operator activated="true" class="read_excel" compatibility="9.8.001" expanded="true" height="68" name="Read Excel (3)" width="90" x="112" y="85">
        <parameter key="excel_file" value="D:/Akademik/twitter duygu analizi makale/data-set/TEST DATA/toplam-R.xlsx"/>
        <parameter key="sheet_number" value="1"/>
        <parameter key="first_row_as_names" value="true"/>
        <parameter key="locale" value="English (United States)"/>
          <parameter key="0" value="ID.true.real.attribute"/>
          <parameter key="1" value="User Name.true.polynominal.attribute"/>
          <parameter key="2" value="Universal Time Stamp.true.polynominal.attribute"/>
          <parameter key="3" value="Local Time Stamp.true.polynominal.attribute"/>
          <parameter key="4" value="Text.true.polynominal.attribute"/>
          <parameter key="5" value="Language.true.polynominal.attribute"/>
          <parameter key="6" value="Profile Image.true.polynominal.attribute"/>
          <parameter key="7" value="Source.true.polynominal.attribute"/>
          <parameter key="8" value="Location.true.polynominal.attribute"/>
          <parameter key="9" value="Time Zone.true.polynominal.attribute"/>
          <parameter key="10" value="Geo.true.polynominal.attribute"/>
          <parameter key="11" value="Hashtags.true.polynominal.attribute"/>
          <parameter key="12" value="Urls.true.polynominal.attribute"/>
          <parameter key="13" value="User Mentions.true.polynominal.attribute"/>
          <parameter key="14" value="Media.true.polynominal.attribute"/>
          <parameter key="15" value="Follower Count.true.integer.attribute"/>
          <parameter key="16" value="Name.true.polynominal.attribute"/>
        </list>
      <operator activated="true" class="select_attributes" compatibility="9.8.001" expanded="true" height="82" name="Select Attributes" width="90" x="246" y="187">
        <parameter key="attribute" value="Text"/>
      <operator activated="true" class="nominal_to_text" compatibility="9.8.001" expanded="true" height="82" name="Nominal to Text" width="90" x="380" y="187">
        <parameter key="attribute_filter_type" value="all"/>
        <parameter key="attribute" value=""/>
        <parameter key="value_type" value="nominal"/>
        <parameter key="except_value_type" value="file_path"/>
        <parameter key="block_type" value="single_value"/>
        <parameter key="except_block_type" value="single_value"/>
      <operator activated="true" class="text:process_document_from_data" compatibility="9.3.001" expanded="true" height="82" name="Process Documents from Data" width="90" x="581" y="187">
        <parameter key="create_word_vector" value="false"/>
        <parameter key="vector_creation" value="TF-IDF"/>
        <parameter key="add_meta_information" value="false"/>
        <parameter key="keep_text" value="true"/>
        <parameter key="prune_method" value="absolute"/>
        <parameter key="prune_below_percent" value="3.0"/>
        <parameter key="prune_above_percent" value="30.0"/>
        <parameter key="prune_below_absolute" value="2"/>
        <parameter key="prune_above_absolute" value="9999"/>
        <parameter key="prune_below_rank" value="0.05"/>
        <parameter key="prune_above_rank" value="0.95"/>
        <parameter key="datamanagement" value="double_sparse_array"/>
        <parameter key="select_attributes_and_weights" value="false"/>
        <list key="specify_weights"/>
          <operator activated="true" class="text:tokenize" compatibility="9.3.001" expanded="true" height="68" name="Tokenize (2)" width="90" x="112" y="34">
            <parameter key="mode" value="non letters"/>
            <parameter key="characters" value=".:"/>
            <parameter key="language" value="English"/>
            <parameter key="max_token_length" value="3"/>
          <operator activated="true" class="text:transform_cases" compatibility="9.3.001" expanded="true" height="68" name="Transform Cases (2)" width="90" x="246" y="34">
            <parameter key="transform_to" value="lower case"/>
          <operator activated="true" class="text:stem_dictionary" compatibility="9.3.001" expanded="true" height="82" name="Stem (Dictionary)" width="90" x="380" y="34">
            <parameter key="file" value="D:/Akademik/twitter duygu analizi makale/data-set/TEST DATA/dict-test.txt"/>
          <operator activated="true" class="text:filter_by_length" compatibility="9.3.001" expanded="true" height="68" name="Filter Tokens (by Length)" width="90" x="581" y="34">
            <parameter key="min_chars" value="4"/>
            <parameter key="max_chars" value="15"/>
          <operator activated="true" class="text:filter_stopwords_dictionary" compatibility="9.3.001" expanded="true" height="82" name="Filter Stopwords (Dictionary)" width="90" x="715" y="34">
            <parameter key="file" value="D:/Akademik/twitter duygu analizi makale/data-set/Stem-dict/stop-words.txt"/>
            <parameter key="case_sensitive" value="false"/>
            <parameter key="encoding" value="UTF-8"/>
          <connect from_port="document" to_op="Tokenize (2)" to_port="document"/>
          <connect from_op="Tokenize (2)" from_port="document" to_op="Transform Cases (2)" to_port="document"/>
          <connect from_op="Transform Cases (2)" from_port="document" to_op="Stem (Dictionary)" to_port="document"/>
          <connect from_op="Stem (Dictionary)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
          <connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Filter Stopwords (Dictionary)" to_port="document"/>
          <connect from_op="Filter Stopwords (Dictionary)" from_port="document" to_port="document 1"/>
        </process>
      <operator activated="true" class="collect" compatibility="9.8.001" expanded="true" height="82" name="Collect" width="90" x="782" y="187">
        <parameter key="unfold" value="false"/>
      <operator activated="true" class="operator_toolbox:apply_model_documents" compatibility="2.8.001" expanded="true" height="103" name="Apply Model (Documents)" width="90" x="916" y="391">
      <connect from_op="Read Excel" from_port="output" to_op="Generate Attributes" to_port="example set input"/>
      <connect from_op="Generate Attributes" from_port="example set output" to_op="Rename" to_port="example set input"/>
      <connect from_op="Rename" from_port="example set output" to_op="Append" to_port="example set 1"/>
      <connect from_op="Read Excel (2)" from_port="output" to_op="Generate Attributes (2)" to_port="example set input"/>
      <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Rename (2)" to_port="example set input"/>
      <connect from_op="Rename (2)" from_port="example set output" to_op="Append" to_port="example set 2"/>
      <connect from_op="Append" from_port="merged set" to_op="Dictionary-Based Sentiment (Documents)" to_port="exa"/>
      <connect from_op="Dictionary-Based Sentiment (Documents)" from_port="mod" to_op="Apply Model (Documents)" to_port="mod"/>
      <connect from_op="Read Excel (3)" from_port="output" to_op="Select Attributes" to_port="example set input"/>
      <connect from_op="Select Attributes" from_port="example set output" to_op="Nominal to Text" to_port="example set input"/>
      <connect from_op="Nominal to Text" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/>
      <connect from_op="Process Documents from Data" from_port="example set" to_op="Collect" to_port="input 1"/>
      <connect from_op="Collect" from_port="collection" to_op="Apply Model (Documents)" to_port="doc"/>
      <connect from_op="Apply Model (Documents)" from_port="exa" to_port="result 1"/>
      <portSpacing port="sink_result 2" spacing="168"/>
      <description align="center" color="yellow" colored="false" height="334" resized="true" width="863" x="69" y="30">This reads tweets from the sheets, tokinize, stem and removing stop words</description>
      <description align="center" color="yellow" colored="false" height="335" resized="true" width="763" x="26" y="454">This generates the dictionary as needed in the &amp;quot;Dict based Sentiment&amp;quot; operator</description>
    </process>
</process>
1 - 1 of 11
    User: "akinozen"
    Accepted Answer
    melihck
    I did it like this.
    <?xml version="1.0" encoding="UTF-8"?><process version="9.8.000">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="9.4.000" expanded="true" name="Process" origin="GENERATED_TUTORIAL">
          <operator activated="true" class="subprocess" compatibility="9.8.000" expanded="true" height="82" name="Subprocess" origin="GENERATED_TUTORIAL" width="90" x="179" y="442">
              <operator activated="false" class="generate_data_user_specification" compatibility="9.8.000" expanded="true" height="68" name="Generate Data by User Specification" origin="GENERATED_TUTORIAL" width="90" x="447" y="289">
                <list key="attribute_values">
                  <parameter key="Key" value="&quot;good&quot;"/>
                  <parameter key="Value" value="1"/>
                </list>
              <operator activated="false" class="generate_data_user_specification" compatibility="9.8.000" expanded="true" height="68" name="Generate Data by User Specification (2)" origin="GENERATED_TUTORIAL" width="90" x="313" y="289">
                  <parameter key="Key" value="&quot;bad&quot;"/>
                  <parameter key="Value" value="-1"/>
                </list>
              <operator activated="false" class="generate_id" compatibility="9.8.000" expanded="true" height="82" name="Generate ID" width="90" x="179" y="289">
                <parameter key="create_nominal_ids" value="false"/>
                <parameter key="offset" value="0"/>
              <operator activated="false" class="retrieve" compatibility="9.8.000" expanded="true" height="68" name="Retrieve ncr_anger" width="90" x="45" y="34">
                <parameter key="repository_entry" value="//Local Repository/DICTIONARY/ncr_anger"/>
              <operator activated="false" class="generate_attributes" compatibility="9.8.000" expanded="true" height="82" name="Generate Attributes (2)" width="90" x="380" y="34">
                  <parameter key="anger" value="anger"/>
                  <parameter key="anger_score" value="SCORE"/>
                </list>
              <operator activated="false" class="retrieve" compatibility="9.8.000" expanded="true" height="68" name="Retrieve ncr_fear" width="90" x="45" y="238">
                <parameter key="repository_entry" value="//Local Repository/DICTIONARY/ncr_fear"/>
              <operator activated="false" class="generate_attributes" compatibility="9.8.000" expanded="true" height="82" name="Generate Attributes (3)" width="90" x="514" y="238">
                  <parameter key="fear" value="fear"/>
                  <parameter key="fear_score" value="score"/>
                </list>
              <operator activated="false" class="retrieve" compatibility="9.8.000" expanded="true" height="68" name="Retrieve ncr_joy" width="90" x="45" y="136">
                <parameter key="repository_entry" value="//Local Repository/DICTIONARY/ncr_joy"/>
              <operator activated="false" class="generate_attributes" compatibility="9.8.000" expanded="true" height="82" name="Generate Attributes" width="90" x="380" y="136">
                  <parameter key="joy" value="joy"/>
                  <parameter key="joy_score" value="SCORE"/>
                </list>
              <operator activated="true" class="retrieve" compatibility="9.8.000" expanded="true" height="68" name="Retrieve ncr_2016_sentiment_SCL-NMA" width="90" x="179" y="85">
                <parameter key="repository_entry" value="ncr_2016_sentiment_SCL-NMA"/>
              <operator activated="true" class="append" compatibility="9.8.000" expanded="true" height="82" name="Append" origin="GENERATED_TUTORIAL" width="90" x="581" y="85">
              <connect from_op="Retrieve ncr_2016_sentiment_SCL-NMA" from_port="output" to_op="Append" to_port="example set 1"/>
              <connect from_op="Append" from_port="merged set" to_port="out 1"/>
            </process>
            <description align="center" color="transparent" colored="false" width="126">Generate dummy dictionary</description>
          <operator activated="true" class="generate_data_user_specification" compatibility="9.8.000" expanded="true" height="68" name="Generate Data by User Specification (3)" origin="GENERATED_TUTORIAL" width="90" x="179" y="595">
              <parameter key="neg" value="&quot;not&quot;"/>
            </list>
          <operator activated="true" class="operator_toolbox:dictionary_sentiment_learner" compatibility="2.8.001" expanded="true" height="103" name="Dictionary Based Sentiment" origin="GENERATED_TUTORIAL" width="90" x="648" y="391">
            <parameter key="value_attribute" value="score"/>
            <parameter key="key_attribute" value="sentiment"/>
            <parameter key="negation_attribute" value="neg"/>
          <operator activated="true" class="retrieve" compatibility="9.8.000" expanded="true" height="68" name="Retrieve Henn na Hotel Huis Ten Bosch" width="90" x="246" y="187">
            <parameter key="repository_entry" value="../ROBOT/Henn na Hotel Huis Ten Bosch"/>
          <operator activated="true" class="nominal_to_text" compatibility="9.8.000" expanded="true" height="82" name="Nominal to Text" width="90" x="380" y="187">
            <parameter key="attribute" value="field-0"/>
          <operator activated="false" class="text:process_document_from_data" compatibility="9.3.001" expanded="true" height="82" name="Process Documents from Data" width="90" x="447" y="85">
            <parameter key="keep_text" value="false"/>
            <parameter key="prune_method" value="none"/>
              <operator activated="true" class="text:transform_cases" compatibility="9.3.001" expanded="true" height="68" name="Transform Cases" width="90" x="112" y="34">
              <operator activated="true" class="text:tokenize" compatibility="9.3.001" expanded="true" height="68" name="Tokenize" width="90" x="313" y="85">
              <operator activated="true" class="text:filter_by_length" compatibility="9.3.001" expanded="true" height="68" name="Filter Tokens (by Length)" width="90" x="447" y="34">
                <parameter key="max_chars" value="25"/>
              <operator activated="true" class="text:filter_stopwords_english" compatibility="9.3.001" expanded="true" height="68" name="Filter Stopwords (English)" width="90" x="581" y="85"/>
              <connect from_port="document" to_op="Transform Cases" to_port="document"/>
              <connect from_op="Transform Cases" from_port="document" to_op="Tokenize" to_port="document"/>
              <connect from_op="Tokenize" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
              <connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
              <connect from_op="Filter Stopwords (English)" from_port="document" to_port="document 1"/>
            </process>
          <operator activated="true" class="text:data_to_documents" compatibility="9.3.001" expanded="true" height="68" name="Data to Documents" width="90" x="514" y="187">
          <operator activated="true" class="loop_collection" compatibility="9.8.000" expanded="true" height="82" name="Loop Collection" width="90" x="648" y="187">
            <parameter key="set_iteration_macro" value="false"/>
            <parameter key="macro_name" value="iteration"/>
            <parameter key="macro_start_value" value="1"/>
              <operator activated="true" class="text:tokenize" compatibility="9.3.001" expanded="true" height="68" name="Tokenize (2)" width="90" x="380" y="85">
              <connect from_port="single" to_op="Tokenize (2)" to_port="document"/>
              <connect from_op="Tokenize (2)" from_port="document" to_port="output 1"/>
              <portSpacing port="source_single" spacing="0"/>
              <portSpacing port="sink_output 1" spacing="0"/>
              <portSpacing port="sink_output 2" spacing="0"/>
            </process>
          <operator activated="true" class="operator_toolbox:apply_model_documents" compatibility="2.8.001" expanded="true" height="103" name="Apply Model (Documents)" origin="GENERATED_TUTORIAL" width="90" x="916" y="340">
          <operator activated="false" class="aggregate" compatibility="9.8.000" expanded="true" height="82" name="Aggregate" width="90" x="916" y="136">
            <parameter key="use_default_aggregation" value="false"/>
            <parameter key="default_aggregation_function" value="average"/>
              <parameter key="Scoring String" value="count"/>
            </list>
            <parameter key="group_by_attributes" value=""/>
            <parameter key="count_all_combinations" value="false"/>
            <parameter key="only_distinct" value="true"/>
            <parameter key="ignore_missings" value="true"/>
          <connect from_op="Subprocess" from_port="out 1" to_op="Dictionary Based Sentiment" to_port="exa"/>
          <connect from_op="Generate Data by User Specification (3)" from_port="output" to_op="Dictionary Based Sentiment" to_port="neg"/>
          <connect from_op="Dictionary Based Sentiment" from_port="mod" to_op="Apply Model (Documents)" to_port="mod"/>
          <connect from_op="Retrieve Henn na Hotel Huis Ten Bosch" from_port="output" to_op="Nominal to Text" to_port="example set input"/>
          <connect from_op="Nominal to Text" from_port="example set output" to_op="Data to Documents" to_port="example set"/>
          <connect from_op="Data to Documents" from_port="documents" to_op="Loop Collection" to_port="collection"/>
          <connect from_op="Loop Collection" from_port="output 1" to_op="Apply Model (Documents)" to_port="doc"/>
        </process>
    </process>
