<?xml version="1.0" encoding="UTF-8"?><process version="9.8.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.8.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="text:read_document" compatibility="9.3.001" expanded="true" height="68" name="JSON" width="90" x="112" y="34"> <parameter key="file" value="C:/Users/mbarradas/Downloads/LucyandYak_2020-09-19_07-52-37_UTC_comments.json"/> <parameter key="extract_text_only" value="true"/> <parameter key="use_file_extension_as_type" value="true"/> <parameter key="content_type" value="txt"/> <parameter key="encoding" value="SYSTEM"/> </operator> <operator activated="true" class="multiply" compatibility="9.8.000" expanded="true" height="103" name="Multiply" width="90" x="179" y="187"/> <operator activated="true" class="text:process_documents" compatibility="9.3.001" expanded="true" height="103" name="Answers" width="90" x="313" y="187"> <parameter key="create_word_vector" value="false"/> <parameter key="vector_creation" value="TF-IDF"/> <parameter key="add_meta_information" value="true"/> <parameter key="keep_text" value="false"/> <parameter key="prune_method" value="none"/> <parameter key="prune_below_percent" value="3.0"/> <parameter key="prune_above_percent" value="30.0"/> <parameter key="prune_below_rank" value="0.05"/> <parameter key="prune_above_rank" value="0.95"/> <parameter key="datamanagement" value="double_sparse_array"/> <parameter key="data_management" value="auto"/> <process expanded="true"> <operator activated="true" class="text:extract_information" compatibility="9.3.001" expanded="true" height="68" name="Extract Information (3)" width="90" x="112" y="34"> <parameter key="query_type" value="JsonPath"/> <list key="string_machting_queries"/> <parameter key="attribute_type" value="Nominal"/> <list key="regular_expression_queries"/> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <parameter key="ignore_CDATA" value="true"/> <parameter key="assume_html" value="true"/> <list key="index_queries"/> <list key="jsonpath_queries"> <parameter key="Id_general" value=".id"/> </list> </operator> <operator activated="true" class="text:cut_document" compatibility="9.3.001" expanded="true" height="68" name="Cut Document (2)" width="90" x="313" y="34"> <parameter key="query_type" value="JsonPath"/> <list key="string_machting_queries"/> <parameter key="attribute_type" value="Nominal"/> <list key="regular_expression_queries"/> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <parameter key="ignore_CDATA" value="true"/> <parameter key="assume_html" value="true"/> <list key="index_queries"/> <list key="jsonpath_queries"> <parameter key="Fila" value=".answers[*]"/> </list> <process expanded="true"> <operator activated="true" class="text:extract_information" compatibility="9.3.001" expanded="true" height="68" name="Extract Information (2)" width="90" x="313" y="34"> <parameter key="query_type" value="JsonPath"/> <list key="string_machting_queries"/> <parameter key="attribute_type" value="Nominal"/> <list key="regular_expression_queries"/> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <parameter key="ignore_CDATA" value="true"/> <parameter key="assume_html" value="true"/> <list key="index_queries"/> <list key="jsonpath_queries"> <parameter key="ID_answer" value=".id"/> <parameter key="created_at_answer" value=".created_at"/> <parameter key="text_answer" value=".text"/> <parameter key="owner.id_answer" value=".owner.id"/> <parameter key="is_verified_answer" value=".is_verified"/> <parameter key="profile_pic_url_answer" value=".profile_pic_url"/> <parameter key="username_answer" value=".username"/> <parameter key="likes_count_answer" value=".likes_count"/> </list> </operator> <operator activated="false" class="de_pivot" compatibility="9.8.000" expanded="true" height="82" name="De-Pivot (2)" width="90" x="313" y="136"> <list key="attribute_name"> <parameter key="id" value="\[\d+]\.id"/> <parameter key="created_at" value="\[\d+]\.created_at"/> <parameter key="text" value="\[\d+]\.text"/> <parameter key="owner_id" value="\[\d+]\.owner.id"/> <parameter key="is_verified" value="\[\d+]\.is_verified"/> <parameter key="profile_pic_url" value="\[\d+]\.profile_pic_url"/> <parameter key="username" value="\[\d+]\.username"/> <parameter key="likes_count" value="\[\d+]\.likes_count"/> </list> <parameter key="index_attribute" value="ID"/> <parameter key="create_nominal_index" value="false"/> <parameter key="keep_missings" value="true"/> </operator> <connect from_port="segment" to_op="Extract Information (2)" to_port="document"/> <connect from_op="Extract Information (2)" from_port="document" to_port="document 1"/> <portSpacing port="source_segment" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_port="document" to_op="Extract Information (3)" to_port="document"/> <connect from_op="Extract Information (3)" from_port="document" to_op="Cut Document (2)" to_port="document"/> <connect from_op="Cut Document (2)" from_port="documents" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:process_documents" compatibility="9.3.001" expanded="true" height="103" name="Processing" width="90" x="246" y="34"> <parameter key="create_word_vector" value="false"/> <parameter key="vector_creation" value="TF-IDF"/> <parameter key="add_meta_information" value="true"/> <parameter key="keep_text" value="false"/> <parameter key="prune_method" value="none"/> <parameter key="prune_below_percent" value="3.0"/> <parameter key="prune_above_percent" value="30.0"/> <parameter key="prune_below_rank" value="0.05"/> <parameter key="prune_above_rank" value="0.95"/> <parameter key="datamanagement" value="double_sparse_array"/> <parameter key="data_management" value="auto"/> <process expanded="true"> <operator activated="true" class="text:cut_document" compatibility="9.3.001" expanded="true" height="68" name="Cut Document" width="90" x="313" y="34"> <parameter key="query_type" value="JsonPath"/> <list key="string_machting_queries"/> <parameter key="attribute_type" value="Nominal"/> <list key="regular_expression_queries"/> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <parameter key="ignore_CDATA" value="true"/> <parameter key="assume_html" value="true"/> <list key="index_queries"/> <list key="jsonpath_queries"> <parameter key="Fila" value=".[*]"/> </list> <process expanded="true"> <operator activated="true" class="text:extract_information" compatibility="9.3.001" expanded="true" height="68" name="Extract Information" width="90" x="313" y="34"> <parameter key="query_type" value="JsonPath"/> <list key="string_machting_queries"/> <parameter key="attribute_type" value="Nominal"/> <list key="regular_expression_queries"/> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <parameter key="ignore_CDATA" value="true"/> <parameter key="assume_html" value="true"/> <list key="index_queries"/> <list key="jsonpath_queries"> <parameter key="Id_general" value=".id"/> <parameter key="created_at" value=".created_at"/> <parameter key="text" value=".text"/> <parameter key="owner.id" value=".owner.id"/> <parameter key="is_verified" value=".is_verified"/> <parameter key="profile_pic_url" value=".profile_pic_url"/> <parameter key="username" value=".username"/> <parameter key="likes_count" value=".likes_count"/> <parameter key="answers" value=".answers"/> </list> </operator> <operator activated="false" class="de_pivot" compatibility="9.8.000" expanded="true" height="82" name="De-Pivot" width="90" x="313" y="136"> <list key="attribute_name"> <parameter key="id" value="\[\d+]\.id"/> <parameter key="created_at" value="\[\d+]\.created_at"/> <parameter key="text" value="\[\d+]\.text"/> <parameter key="owner_id" value="\[\d+]\.owner.id"/> <parameter key="is_verified" value="\[\d+]\.is_verified"/> <parameter key="profile_pic_url" value="\[\d+]\.profile_pic_url"/> <parameter key="username" value="\[\d+]\.username"/> <parameter key="likes_count" value="\[\d+]\.likes_count"/> </list> <parameter key="index_attribute" value="ID"/> <parameter key="create_nominal_index" value="false"/> <parameter key="keep_missings" value="true"/> </operator> <connect from_port="segment" to_op="Extract Information" to_port="document"/> <connect from_op="Extract Information" from_port="document" to_port="document 1"/> <portSpacing port="source_segment" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_port="document" to_op="Cut Document" to_port="document"/> <connect from_op="Cut Document" from_port="documents" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="concurrency:join" compatibility="9.8.000" expanded="true" height="82" name="Join" width="90" x="514" y="85"> <parameter key="remove_double_attributes" value="true"/> <parameter key="join_type" value="left"/> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="Id_general" value="Id_general"/> </list> <parameter key="keep_both_join_attributes" value="false"/> </operator> <connect from_op="JSON" from_port="output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Processing" to_port="documents 1"/> <connect from_op="Multiply" from_port="output 2" to_op="Answers" to_port="documents 1"/> <connect from_op="Answers" from_port="example set" to_op="Join" to_port="right"/> <connect from_op="Processing" from_port="example set" to_op="Join" to_port="left"/> <connect from_op="Join" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
