In generate attribute getting error in this condition "if(CY +%{opt}+ Avg3Yr_percentage,60,20)"
opt macro contain "<"
for reference i have attched my process and input file
<?xml version="1.0" encoding="UTF-8"?><process version="9.5.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.5.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.5.001" expanded="true" height="68" name="Retrieve testSgn" width="90" x="45" y="85">
<parameter key="repository_entry" value="//Local Repository/FinancialData/FinalProcess-2020/data/testSgn"/>
<operator activated="true" class="generate_attributes" compatibility="9.5.001" expanded="true" height="82" name="Generate Attributes (2)" width="90" x="179" y="85">
<parameter key="thresh" value=""<,0.4""/>
</list>
<parameter key="keep_all" value="true"/>
<operator activated="true" class="split" compatibility="9.5.001" expanded="true" height="82" name="Split" width="90" x="313" y="85">
<parameter key="attribute" value="thresh"/>
<parameter key="value_type" value="nominal"/>
<parameter key="except_value_type" value="file_path"/>
<parameter key="block_type" value="single_value"/>
<parameter key="except_block_type" value="single_value"/>
<parameter key="split_pattern" value=","/>
<parameter key="split_mode" value="ordered_split"/>
<operator activated="true" class="extract_macro" compatibility="9.5.001" expanded="true" height="68" name="Extract Macro" width="90" x="447" y="85">
<parameter key="macro" value="opt"/>
<parameter key="macro_type" value="data_value"/>
<parameter key="statistics" value="average"/>
<parameter key="attribute_name" value="thresh_1"/>
<parameter key="example_index" value="1"/>
<list key="additional_macros">
<parameter key="percentage" value="thresh_2"/>
</list>
<operator activated="true" class="guess_types" compatibility="9.5.001" expanded="true" height="82" name="Guess Types" width="90" x="581" y="85">
<parameter key="attribute_filter_type" value="all"/>
<parameter key="attribute" value=""/>
<parameter key="decimal_point_character" value="."/>
<operator activated="true" class="generate_attributes" compatibility="9.5.001" expanded="true" height="82" name="Generate Attributes" width="90" x="715" y="85">
<parameter key="Avg3Yr_percentage" value="(Avg3Yr*eval(%{percentage}))"/>
<parameter key="Score" value="if(CY +#{opt}+ Avg3Yr_percentage,60,20)"/>
</list>
<operator activated="false" class="generate_attributes" compatibility="9.5.001" expanded="true" height="82" name="Generate Attributes (3)" width="90" x="581" y="391">
<parameter key="Score" value="if(CY +%{opt}+ Avg3Yr_percentage,60,20)"/>
</list>
<connect from_op="Retrieve testSgn" from_port="output" to_op="Generate Attributes (2)" to_port="example set input"/>
<connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Split" to_port="example set input"/>
<connect from_op="Split" from_port="example set output" to_op="Extract Macro" to_port="example set"/>
<connect from_op="Extract Macro" from_port="example set" to_op="Guess Types" to_port="example set input"/>
<connect from_op="Guess Types" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/>
</process>
</process>
