Hi I am currently using RapidMiner Studio to help me design my streaming workflows. I have an issue regarding spark connector. What I am trying to achieve is to design a simple workflow and upload it to my local spark cluster. My workflow consists of a spark connector(Retrieve) and a Streaming Nest(Contains a Kafka Source, an aggregate, and a sink). I have managed to execute the same workflow using flink connector, upload it to flink cluster and perform some testing with my kafka source and sink. So the rest of the workflow is definitely working properly. I assume that my problem is with the configuration settings of my connection, so I would like if possible to guide me through the steps and all configurations needed to perform a successful connection with my local spark cluster. Note that after all the configuration tests I performed, "Test connection" field showcased that the connection was successful, which does not seem to be right in my case.
<?xml version="1.0" encoding="UTF-8"?><process version="9.7.002">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.7.002" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.7.002" expanded="true" height="68" name="Retrieve SparkConnection" width="90" x="112" y="136">
<parameter key="repository_entry" value="SparkConnection"/>
<operator activated="true" class="streaming:streaming_nest" compatibility="0.1.000-SNAPSHOT" expanded="true" height="82" name="Streaming Nest (2)" width="90" x="380" y="136">
<parameter key="job_name" value="JobShow"/>
<operator activated="true" class="retrieve" compatibility="9.7.002" expanded="true" height="68" name="Retrieve MyKafka (5)" width="90" x="45" y="34">
<parameter key="repository_entry" value="MyKafka"/>
<operator activated="true" class="streaming:kafka_source" compatibility="0.1.000-SNAPSHOT" expanded="true" height="68" name="Kafka Source (2)" width="90" x="179" y="85">
<parameter key="topic" value="input"/>
<parameter key="start_from_earliest" value="false"/>
<operator activated="true" class="streaming:aggregate" compatibility="0.1.000-SNAPSHOT" expanded="true" height="68" name="Aggregate Stream (2)" width="90" x="380" y="136">
<parameter key="key" value="word"/>
<parameter key="value_key" value="value"/>
<parameter key="window_length" value="10"/>
<parameter key="function" value="Sum"/>
<operator activated="true" class="retrieve" compatibility="9.7.002" expanded="true" height="68" name="Retrieve MyKafka (6)" width="90" x="380" y="34">
<operator activated="true" class="streaming:kafka_sink" compatibility="0.1.000-SNAPSHOT" expanded="true" height="82" name="Kafka Sink (4)" width="90" x="581" y="34">
<parameter key="topic" value="output"/>
<connect from_op="Retrieve MyKafka (5)" from_port="output" to_op="Kafka Source (2)" to_port="connection"/>
<connect from_op="Kafka Source (2)" from_port="output stream" to_op="Aggregate Stream (2)" to_port="input stream"/>
<connect from_op="Aggregate Stream (2)" from_port="output stream" to_op="Kafka Sink (4)" to_port="input stream"/>
<connect from_op="Retrieve MyKafka (6)" from_port="output" to_op="Kafka Sink (4)" to_port="connection"/>
</process>
<connect from_op="Retrieve SparkConnection" from_port="output" to_op="Streaming Nest (2)" to_port="connection"/>
<connect from_op="Streaming Nest (2)" from_port="out 1" to_port="result 1"/>
</process>
</process>
