There seems to be a problem with the parameter
sdy1401
sdy1401 New Altair Community Member
edited November 5 in Community Q&A
Hi I'm Dongryeol Shin
There seems to be a problem with the parameter "enable parallel execution" of the loop operator.
I am using GBT model 10 times in parallel using "enable parallel execution" in loop.
At first it is running fine and after a few hours, the process does not proceed as follows.
It stays still in this state.
The CPU and memory are also used at first, but after a few hours, the CPU is not used, and the memory is full.
Can you tell me what this is wrong with?
Could it be a loop parallel bug?
Thank you.
process running
After the process stops
Best Answer
