Im trying to use the set macro operator for filtering by using the golf example set. However it does not work and I cant find the reason for it.
Does anybody know why? - Thank you!
<?xml version="1.0" encoding="UTF-8"?><process version="9.7.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.7.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.7.000" expanded="true" height="68" name="Retrieve Golf" width="90" x="179" y="34">
<parameter key="repository_entry" value="//Samples/data/Golf"/>
<operator activated="true" class="filter_examples" compatibility="9.7.000" expanded="true" height="103" name="Filter Examples" width="90" x="313" y="34">
<parameter key="parameter_expression" value=""/>
<parameter key="condition_class" value="custom_filters"/>
<parameter key="invert_filter" value="false"/>
<list key="filters_list">
<parameter key="filters_entry_key" value="Outlook.equals.%{outlookvalue}"/>
</list>
<parameter key="filters_logic_and" value="true"/>
<parameter key="filters_check_metadata" value="true"/>
<operator activated="true" class="set_macro" compatibility="9.7.000" expanded="true" height="68" name="Set Macro" width="90" x="45" y="34">
<parameter key="macro" value="outlookvalue"/>
<parameter key="value" value="rain"/>
<operator activated="true" class="retrieve" compatibility="9.7.000" expanded="true" height="68" name="Retrieve Golf (2)" width="90" x="179" y="187">
<operator activated="true" class="filter_examples" compatibility="9.7.000" expanded="true" height="103" name="Filter Examples (2)" width="90" x="313" y="187">
<parameter key="filters_entry_key" value="Outlook.equals.rain"/>
</list>
<connect from_op="Retrieve Golf" from_port="output" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Filter Examples" from_port="example set output" to_port="result 1"/>
<connect from_op="Retrieve Golf (2)" from_port="output" to_op="Filter Examples (2)" to_port="example set input"/>
<connect from_op="Filter Examples (2)" from_port="example set output" to_port="result 2"/>
</process>
</process>
