converting results into excel
Thiru
dear all,
is there any way to convert the results page - data and statistics into excel for further usage.
thanks
thiru
Excel
MartinLiebig
what you can do is use the Extract Statistics operator. This converts all the information you see in the Stats view into an example set. You can then use Write Excel to write it into an excel file.
Cheers,
Martin
Thiru
@mschmitz
thanks for your reply. I tried this. while using write excel, im not able to see the parameter " file location'. to access further. could you pl. look into this.( ive just enclosed the process pic) thanks
regds
thiru
lionelderkrikor
Hi
@Thiru
Connect the
thr
port of the
Write Excel
(instead of the
fil
port).
regards,
Lionel
Thiru
@lionelderkrikor
yes. thanks. I did that ,
1. I connected thr port and run the process & am getting en excel file in the destination folder.
However, im not able to open the excel file
in MS Excel.
I get the warning:
" excel cannot open the file because the file format is not valid. verify that the file has not been corrupted and that the file extension matches the format of the file"
2. I thought of using 'read excel' operator in to open the same file in
rapidminer
again couldnt. it says: e
rror in opening zip file.
(see the enclosed jpeg file for error).
3. Then I tried open the same with 'read excel with format' ,
now it opens
I thought of checking why it doesnt happen if I use normal MS excel file , as well as if I use through rapidminer in step 2.
can you help. thanks.
II. Moreover - I realise the 'extract statistics' operator help to to extract the " statistics"
But
how to extract the " data "
i.e. information in 'data' view in results?
regds
thiru
