here is the xlm:
<?xml version="1.0" encoding="UTF-8"?><process version="9.7.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.7.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.7.000" expanded="true" height="68" name="Retrieve dataset" width="90" x="179" y="34">
<parameter key="repository_entry" value="//HEALTH_ANALYTICS/dataset"/>
<operator activated="true" class="generate_attributes" compatibility="9.7.000" expanded="true" height="82" name="Generate Attributes (2)" width="90" x="380" y="34">
<parameter key="Test" value="date_parse_custom([Time],"HH:mm:ss","it")"/>
</list>
<parameter key="keep_all" value="true"/>
<connect from_op="Retrieve dataset" from_port="output" to_op="Generate Attributes (2)" to_port="example set input"/>
<connect from_op="Generate Attributes (2)" from_port="example set output" to_port="result 1"/>
</process>
</process>
