Hi, I have about 1000 datasets that I want to enter the Rapid Miner software once because it is diff
moni
Hi, I have about 1000 datasets that I want to enter the Rapid Miner software once because it is difficult to enter two by one, can anyone help ??
hughesfleming68
Loop files is what you are looking for. Inside you would put a read csv. Depending on your license, you could easily hit a limit.
moni
They are full of answers
Can you help me by sending me an instructional video?
lionelderkrikor
Hi
@moni
As mentioned by
@hughesfleming68
, you have to implement a
Read CSV
operator inside a
Loop Files
operator.
Set the path where your files are stored in the parameters of the
Loop Files
operator.
If you want to store all your files as example sets in your repository, use a
Store
operator.
In the parameters of
Store
operator, set the repository and give the name
%{file_name}
to the example set.
In attached file, a general process to perform what you want to do.
Hope this helps,
Lionel
Loop_Files.rmp
moni
@lionelderkrikor
tankyou for nswer me
i want append all dataset to one dataset but ha
ve this error wich send you by imge and don't want a column to be deleted
hughesfleming68
What do you expect your final table to look like? Is it one huge table or are you trying to do something else? Can you take three of your 1000 files give an example of what order you need the data?
moni
hughesfleming68
I have 600 data sets that are of the txt type. I want these 600 data to become a dataset in the event, and when I insert them as input in the repository, the output can be as shown below....All 600 dataset is converted into a file txt that when I call, a table of 600 is shown to me as shown below.
رهاورد.rar
sara20
@moni
سلام. وقت بخیر
اگر اشتباه نکنم شما 600 ستون در فایل خود دارید که در حقیقت همان تعداد ویژگی های شما است. درست عرض کردم؟
حالا با توجه به این دیتا هدف شما پیاده سازی چه فرایندی است؟
سارا
moni
sara20
سلام وقت شما هم بخیر من 600 تا دیتاست دارم هر کدوم از دیتا ست های من یک فایل متنی می باشد من میخوام این 600 تا دیتا ست تبدیل به
یک دیتاست بشوند من دیتا ست رو ارسال می کنم ببیند هر دیتا ست رو که با باز می کنید ستون های مانند دیتاست های مابقی را دارد ولی رکوردها متفاوت هستند میخوام به جای کار روی 600 تا دیتا ست روی 1 دیتاست کار کنم چون همنطور که عرض شد ستون همه دیتاست ها مانند هم هستند فقط رکورد ها دارای فلید های مختلف هست.
moni
sara20
رهاورد.rar
sara20
سلام
جواب لیونل درست هست اگر نتوانستید با آن کار کنید بنظرم با پایتون میتوانید کدی بنویسید و کل فایل های خود را یکسان کنید سپس طبق فایل مورد نظر پیاده سازی انجام دهید
https://docs.rapidminer.com/latest/studio/operators/utility/process_control/loops/loop.html#:~:text=Inside%20the%20Loop%20operator%2C%20nothing,the%20results%20of%20each%20iteration.
https://docs.rapidminer.com/latest/studio/operators/utility/process_control/loops/loop_examples.html
https://docs.rapidminer.com/latest/studio/operators/utility/process_control/loops/loop_attributes.html
https://docs.rapidminer.com/latest/studio/operators/utility/process_control/loops/loop_values.html
در رابطه با اوپراتور لوپ هم لینک های فوق میتوانند به شما اطلاعات بیشتری بدهند
موفق باشید
سارا
moni
sara20
آیا کد پایتون را برایم میفرستید؟ که برای کل فایل رو یکسان کنم؟
sara20
متاسفانه من تا حالا کدش ننوشتم ولی از بین دوستان دیدم افرادی که با پایتون کد میزنن و فایلها را حتی از سایت های مختلف فراخوانی میکنند و نتایجش با سیستم تجمیع میکنند و معمولا برای این کار باید اسکرپر بنویسید اگر تو نت سرچ کنید کداش مییتونید پیدا کنید
moni
@sara20
مواردی که ارسال کردید همگی مربوط به جدا کردن سطر یا ستون از یک دیتاست هستند و سوال من پاسخ داده نشده است در واقعه من چندتا فایل دیتاست دارم می خواهم یکی شوند و فایل ها رو خدمتون ارسال کردم
sara20
در این زمینه متاسفانه اطلاعات بیشتری ندارم. اما باز هم در انجمن سرچ کنید شاید مطلب بهتری پیدا کنید
با احترام
سارا
moni
I need your help to how append file convert to
one file Using loop file?
test.rar
moni
@sara20
سلام شما به من کمک می کنید؟
من هنوز مشکلم حل نشد می توانید رو سیستم خودتون امتحان کنید به احتمال زیاد می تونید کمک کنید یه نمونه کوچک را خدمتون ارسال کردم
تشکر
test.rar
