Logistic Regression with polynominal attributes
User: "jykim"
New Altair Community Member
Updated by Jocelyn
Novice here. My member type is a university professor but not in the data science field.
I am trying to run logistic regression using the data downloaded from here: https://www.kaggle.com/fayomi/advertising. As stated in the data description of the site, the goal is to predict people who are more likely to click the ad. I split the data into training and scoring data.
I want to get some help in how to handle the polynominal attributes in the data set. For example, there are so many Ad Topic Line and City values. When I ran the model, it ran but the results did not look right.
Also, the confidence percentage for ad click (yes, no) was either one or zero for all rows. I feel something might be wrong here.
Thanks for help...
1 - 1 of 11
    User: "sgenzer"
    Accepted Answer
    hi @jykim so that was fun. Here's a quick solution.
    <?xml version="1.0" encoding="UTF-8"?><process version="9.6.000">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process">
        <process expanded="true">
          <operator activated="true" class="retrieve" compatibility="9.6.000" expanded="true" height="68" name="Retrieve advertising" width="90" x="45" y="85">
            <parameter key="repository_entry" value="//NewLocalRepository/advertising"/>
          <operator activated="true" class="subprocess" compatibility="9.6.000" expanded="true" height="82" name="Subprocess" width="90" x="179" y="85">
              <operator activated="true" class="nominal_to_text" compatibility="9.6.000" expanded="true" height="82" name="Nominal to Text" width="90" x="45" y="34">
                <parameter key="attribute" value="Ad Topic Line"/>
                <parameter key="value_type" value="nominal"/>
                <parameter key="except_value_type" value="file_path"/>
                <parameter key="block_type" value="single_value"/>
                <parameter key="except_block_type" value="single_value"/>
              <operator activated="true" class="text:process_document_from_data" compatibility="9.3.001" expanded="true" height="82" name="Process Documents from Data" width="90" x="179" y="34">
                <parameter key="create_word_vector" value="true"/>
                <parameter key="vector_creation" value="TF-IDF"/>
                <parameter key="add_meta_information" value="true"/>
                <parameter key="keep_text" value="true"/>
                <parameter key="prune_method" value="percentual"/>
                <parameter key="prune_below_percent" value="2.0"/>
                <parameter key="prune_above_percent" value="30.0"/>
                <parameter key="prune_below_rank" value="0.05"/>
                <parameter key="prune_above_rank" value="0.95"/>
                <parameter key="datamanagement" value="double_sparse_array"/>
                <parameter key="data_management" value="auto"/>
                <parameter key="select_attributes_and_weights" value="false"/>
                <list key="specify_weights"/>
                  <operator activated="true" class="text:tokenize" compatibility="9.3.001" expanded="true" height="68" name="Tokenize" width="90" x="45" y="34">
                    <parameter key="mode" value="non letters"/>
                    <parameter key="characters" value=".:"/>
                    <parameter key="language" value="English"/>
                    <parameter key="max_token_length" value="3"/>
                  <connect from_port="document" to_op="Tokenize" to_port="document"/>
                  <connect from_op="Tokenize" from_port="document" to_port="document 1"/>
                </process>
              <operator activated="true" class="numerical_to_binominal" compatibility="9.6.000" expanded="true" height="82" name="Numerical to Binominal" width="90" x="313" y="34">
                <parameter key="attribute" value="Clicked on Ad"/>
                <parameter key="value_type" value="numeric"/>
                <parameter key="except_value_type" value="real"/>
                <parameter key="block_type" value="value_series"/>
                <parameter key="except_block_type" value="value_series_end"/>
                <parameter key="min" value="0.0"/>
                <parameter key="max" value="0.0"/>
              <operator activated="true" class="set_role" compatibility="9.6.000" expanded="true" height="82" name="Set Role" width="90" x="447" y="34">
                <parameter key="attribute_name" value="Clicked on Ad"/>
              <operator activated="true" class="map" compatibility="9.6.000" expanded="true" height="82" name="Map" width="90" x="581" y="34">
                <parameter key="attribute" value="Country"/>
                <list key="value_mappings">
                  <parameter key="United States of America" value="United States"/>
                  <parameter key="Antarctica (the territory South of 60 deg S)" value="Antarctica"/>
                  <parameter key="Bouvet Island (Bouvetoya)" value="Bouvet Island"/>
                  <parameter key="British Indian Ocean Territory (Chagos Archipelago)" value="British Indian Ocean Territory"/>
                  <parameter key="Brunei Darussalam" value="Brunei"/>
                  <parameter key="Cote d'Ivoire" value="Ivory Coast (Côte d'Ivoire)"/>
                  <parameter key="Falkland Islands (Malvinas)" value="Falkland Islands"/>
                  <parameter key="Gambia" value="The Gambia"/>
                  <parameter key="Holy See (Vatican City State)" value="Vatican City"/>
                  <parameter key="Korea" value="South Korea"/>
                  <parameter key="Kyrgyz Republic" value="Kyrgyzstan"/>
                  <parameter key="Lao People's Democratic Republic" value="Laos"/>
                  <parameter key="Libyan Arab Jamahiriya" value="Libya"/>
                  <parameter key="Macao" value="Macau"/>
                  <parameter key="Micronesia" value="Federated States of Micronesia"/>
                  <parameter key="Netherlands Antilles" value="Caribbean Netherlands (Bonaire, Sint Eustatius and Saba)"/>
                  <parameter key="Palestinian Territory" value="Palestine"/>
                  <parameter key="Reunion" value="Réunion"/>
                  <parameter key="Russian Federation" value="Russia"/>
                  <parameter key="Saint Barthelemy" value="Saint Barthélemy"/>
                  <parameter key="Saint Helena" value="Saint Helena, Ascension and Tristan da Cunha"/>
                  <parameter key="Saint Martin" value="Saint Martin (French part)"/>
                  <parameter key="Sao Tome and Principe" value="São Tomé and Principé"/>
                  <parameter key="Slovakia (Slovak Republic)" value="Slovakia"/>
                  <parameter key="Svalbard &amp; Jan Mayen Islands" value="Svalbard and Jan Mayen"/>
                  <parameter key="Syrian Arab Republic" value="Syria"/>
                  <parameter key="Timor-Leste" value="East Timor"/>
                </list>
                <parameter key="consider_regular_expressions" value="false"/>
                <parameter key="add_default_mapping" value="false"/>
              <operator activated="true" class="retrieve" compatibility="9.6.000" expanded="true" height="68" name="Retrieve World Countries" width="90" x="179" y="238">
                <parameter key="repository_entry" value="//Community Samples/Community Data Sets/World Geography/World Countries"/>
              <operator activated="true" class="select_attributes" compatibility="9.6.000" expanded="true" height="82" name="Select Attributes" width="90" x="313" y="238">
                <parameter key="attribute" value=""/>
                <parameter key="attributes" value="Country Name|UN continental region"/>
              <operator activated="true" class="concurrency:join" compatibility="9.6.000" expanded="true" height="82" name="Join" width="90" x="782" y="136">
                <parameter key="remove_double_attributes" value="true"/>
                <parameter key="join_type" value="left"/>
                <parameter key="use_id_attribute_as_key" value="false"/>
                <list key="key_attributes">
                  <parameter key="Country" value="Country Name"/>
                </list>
                <parameter key="keep_both_join_attributes" value="false"/>
              <operator activated="true" class="nominal_to_numerical" compatibility="9.6.000" expanded="true" height="103" name="Nominal to Numerical" width="90" x="916" y="136">
                <parameter key="return_preprocessing_model" value="false"/>
                <parameter key="create_view" value="false"/>
                <parameter key="attribute" value="UN continental region"/>
                <parameter key="coding_type" value="dummy coding"/>
                <parameter key="use_comparison_groups" value="false"/>
                <list key="comparison_groups"/>
                <parameter key="unexpected_value_handling" value="all 0 and warning"/>
                <parameter key="use_underscore_in_name" value="false"/>
              <operator activated="true" class="date_to_numerical" compatibility="9.6.000" expanded="true" height="82" name="Date to Numerical" width="90" x="1050" y="136">
                <parameter key="attribute_name" value="Timestamp"/>
                <parameter key="time_unit" value="hour"/>
                <parameter key="millisecond_relative_to" value="epoch"/>
                <parameter key="second_relative_to" value="minute"/>
                <parameter key="minute_relative_to" value="hour"/>
                <parameter key="hour_relative_to" value="day"/>
                <parameter key="day_relative_to" value="month"/>
                <parameter key="week_relative_to" value="year"/>
                <parameter key="month_relative_to" value="year"/>
                <parameter key="quarter_relative_to" value="year"/>
                <parameter key="half_year_relative_to" value="year"/>
                <parameter key="year_relative_to" value="era"/>
                <parameter key="keep_old_attribute" value="true"/>
              <operator activated="true" class="date_to_numerical" compatibility="9.6.000" expanded="true" height="82" name="Date to Numerical (2)" width="90" x="1184" y="136">
                <parameter key="time_unit" value="day"/>
                <parameter key="day_relative_to" value="week"/>
              <operator activated="true" class="date_to_numerical" compatibility="9.6.000" expanded="true" height="82" name="Date to Numerical (3)" width="90" x="1318" y="136">
                <parameter key="time_unit" value="week"/>
              <operator activated="true" class="date_to_numerical" compatibility="9.6.000" expanded="true" height="82" name="Date to Numerical (4)" width="90" x="1452" y="136">
                <parameter key="keep_old_attribute" value="false"/>
              <operator activated="true" class="generate_attributes" compatibility="9.6.000" expanded="true" height="82" name="Generate Attributes" width="90" x="1653" y="136">
                <list key="function_descriptions"/>
                <parameter key="keep_all" value="true"/>
              <operator activated="true" class="select_attributes" compatibility="9.6.000" expanded="true" height="82" name="Select Attributes (2)" width="90" x="1787" y="136">
                <parameter key="attributes" value="City|Country|Country Name|text"/>
              <connect from_port="in 1" to_op="Nominal to Text" to_port="example set input"/>
              <connect from_op="Nominal to Text" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/>
              <connect from_op="Process Documents from Data" from_port="example set" to_op="Numerical to Binominal" to_port="example set input"/>
              <connect from_op="Numerical to Binominal" from_port="example set output" to_op="Set Role" to_port="example set input"/>
              <connect from_op="Set Role" from_port="example set output" to_op="Map" to_port="example set input"/>
              <connect from_op="Map" from_port="example set output" to_op="Join" to_port="left"/>
              <connect from_op="Retrieve World Countries" from_port="output" to_op="Select Attributes" to_port="example set input"/>
              <connect from_op="Select Attributes" from_port="example set output" to_op="Join" to_port="right"/>
              <connect from_op="Join" from_port="join" to_op="Nominal to Numerical" to_port="example set input"/>
              <connect from_op="Nominal to Numerical" from_port="example set output" to_op="Date to Numerical" to_port="example set input"/>
              <connect from_op="Date to Numerical" from_port="example set output" to_op="Date to Numerical (2)" to_port="example set input"/>
              <connect from_op="Date to Numerical (2)" from_port="example set output" to_op="Date to Numerical (3)" to_port="example set input"/>
              <connect from_op="Date to Numerical (3)" from_port="example set output" to_op="Date to Numerical (4)" to_port="example set input"/>
              <connect from_op="Date to Numerical (4)" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
              <connect from_op="Generate Attributes" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/>
              <connect from_op="Select Attributes (2)" from_port="example set output" to_port="out 1"/>
              <portSpacing port="source_in 2" spacing="0"/>
            </process>
          <operator activated="true" class="concurrency:cross_validation" compatibility="9.6.000" expanded="true" height="145" name="Cross Validation" width="90" x="313" y="85">
            <parameter key="split_on_batch_attribute" value="false"/>
            <parameter key="leave_one_out" value="false"/>
            <parameter key="number_of_folds" value="10"/>
            <parameter key="sampling_type" value="automatic"/>
            <parameter key="use_local_random_seed" value="false"/>
            <parameter key="local_random_seed" value="1992"/>
            <parameter key="enable_parallel_execution" value="true"/>
              <operator activated="true" class="h2o:logistic_regression" compatibility="9.3.001" expanded="true" height="124" name="Logistic Regression" width="90" x="112" y="34">
                <parameter key="solver" value="AUTO"/>
                <parameter key="reproducible" value="false"/>
                <parameter key="maximum_number_of_threads" value="4"/>
                <parameter key="use_regularization" value="false"/>
                <parameter key="lambda_search" value="false"/>
                <parameter key="number_of_lambdas" value="0"/>
                <parameter key="lambda_min_ratio" value="0.0"/>
                <parameter key="early_stopping" value="true"/>
                <parameter key="stopping_rounds" value="3"/>
                <parameter key="stopping_tolerance" value="0.001"/>
                <parameter key="standardize" value="true"/>
                <parameter key="non-negative_coefficients" value="false"/>
                <parameter key="add_intercept" value="true"/>
                <parameter key="compute_p-values" value="true"/>
                <parameter key="remove_collinear_columns" value="true"/>
                <parameter key="missing_values_handling" value="MeanImputation"/>
                <parameter key="max_iterations" value="0"/>
                <parameter key="max_runtime_seconds" value="0"/>
              <connect from_port="training set" to_op="Logistic Regression" to_port="training set"/>
              <connect from_op="Logistic Regression" from_port="model" to_port="model"/>
              <portSpacing port="source_training set" spacing="0"/>
            </process>
              <operator activated="true" class="apply_model" compatibility="9.6.000" expanded="true" height="82" name="Apply Model" width="90" x="45" y="34">
              <operator activated="true" class="performance_binominal_classification" compatibility="9.6.000" expanded="true" height="82" name="Performance" width="90" x="179" y="34">
                <parameter key="manually_set_positive_class" value="false"/>
                <parameter key="main_criterion" value="first"/>
                <parameter key="accuracy" value="true"/>
                <parameter key="classification_error" value="false"/>
                <parameter key="kappa" value="false"/>
                <parameter key="AUC (optimistic)" value="false"/>
                <parameter key="AUC" value="false"/>
                <parameter key="AUC (pessimistic)" value="false"/>
                <parameter key="precision" value="false"/>
                <parameter key="recall" value="false"/>
                <parameter key="lift" value="false"/>
                <parameter key="fallout" value="false"/>
                <parameter key="f_measure" value="false"/>
                <parameter key="false_positive" value="false"/>
                <parameter key="false_negative" value="false"/>
                <parameter key="true_positive" value="false"/>
                <parameter key="true_negative" value="false"/>
                <parameter key="sensitivity" value="false"/>
                <parameter key="specificity" value="false"/>
                <parameter key="youden" value="false"/>
                <parameter key="positive_predictive_value" value="false"/>
                <parameter key="negative_predictive_value" value="false"/>
                <parameter key="psep" value="false"/>
                <parameter key="skip_undefined_labels" value="true"/>
                <parameter key="use_example_weights" value="true"/>
              <connect from_port="model" to_op="Apply Model" to_port="model"/>
              <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
              <connect from_op="Performance" from_port="performance" to_port="performance 1"/>
              <portSpacing port="sink_test set results" spacing="0"/>
              <portSpacing port="sink_performance 1" spacing="0"/>
              <portSpacing port="sink_performance 2" spacing="0"/>
            </process>
          <connect from_op="Retrieve advertising" from_port="output" to_op="Subprocess" to_port="in 1"/>
          <connect from_op="Subprocess" from_port="out 1" to_op="Cross Validation" to_port="example set"/>
          <connect from_op="Cross Validation" from_port="model" to_port="result 1"/>
          <connect from_op="Cross Validation" from_port="example set" to_port="result 2"/>
          <connect from_op="Cross Validation" from_port="performance 1" to_port="result 3"/>
        </process>
    </process>
    Scott
