I am working on Optistruct user profile and I am not able to see EIGRL card as an available card image for the load collector. Is there something I should do to enable it ?
You can use 'Ctrl+F' and type 'EIGRL'. It will create the card automatically.
EIGRL and some other loadstep input were moved to a new entity called 'loadstep inputs'. Take a look at your browsers.
In newer version i'd suggest you to use more the browsers for creating these cards.
You can use 'Ctrl+F' and type 'EIGRL'. It will create the card automatically. EIGRL and some other loadstep input were moved to a new entity called 'loadstep inputs'. Take a look at your browsers. In newer version i'd suggest you to use more the browsers for creating these cards.
Thank you very much, i found it in LoadStep Input
