<?xml version="1.0" encoding="UTF-8"?><process version="9.6.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process" origin="GENERATED_TUTORIAL"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" breakpoints="after" class="retrieve" compatibility="9.6.000" expanded="true" height="68" name="Iris" origin="GENERATED_TUTORIAL" width="90" x="313" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="handle_exception" compatibility="9.6.000" expanded="true" height="82" name="Handle Exception" origin="GENERATED_TUTORIAL" width="90" x="514" y="30"> <parameter key="add_details_to_log" value="false"/> <process expanded="true"> <operator activated="true" class="rename" compatibility="9.6.000" expanded="true" height="76" name="Rename" origin="GENERATED_TUTORIAL" width="90" x="112" y="30"> <parameter key="old_name" value=""/> <list key="rename_additional_attributes"> <parameter key="a1" value="att1"/> <parameter key="a2" value="att2"/> <parameter key="a3" value="att3"/> <parameter key="a4" value="att4"/> </list> </operator> <connect from_port="in 1" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="log" compatibility="9.6.000" expanded="true" height="76" name="Log" origin="GENERATED_TUTORIAL" width="90" x="112" y="30"> <list key="log"> <parameter key="error message" value="operator.Handle Exception.value.exception"/> </list> <parameter key="sorting_type" value="none"/> <parameter key="sorting_k" value="100"/> <parameter key="persistent" value="false"/> </operator> <connect from_port="in 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_op="Iris" from_port="output" to_op="Handle Exception" to_port="in 1"/> <connect from_op="Handle Exception" from_port="out 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="72"/> </process> </operator> </process>
