<?xml version="1.0" encoding="UTF-8"?><process version="9.6.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="utility:create_exampleset" compatibility="9.6.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="112" y="34"> <parameter key="generator_type" value="date series"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"> <parameter key="Date" value="2019-01-01.2020-12-31"/> </list> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="generate_copy" compatibility="9.6.000" expanded="true" height="82" name="Generate Copy" width="90" x="246" y="34"> <parameter key="attribute_name" value="Date"/> <parameter key="new_name" value="Quarter"/> </operator> <operator activated="true" class="generate_copy" compatibility="9.6.000" expanded="true" height="82" name="Generate Copy (2)" width="90" x="380" y="34"> <parameter key="attribute_name" value="Date"/> <parameter key="new_name" value="Year"/> </operator> <operator activated="true" class="multiply" compatibility="9.6.000" expanded="true" height="103" name="Multiply" width="90" x="514" y="34"/> <operator activated="true" class="generate_attributes" compatibility="9.6.000" expanded="true" height="82" name="Second_Option" width="90" x="648" y="238"> <list key="function_descriptions"> <parameter key="Quarter" value="concat("Q",str(floor((date_get(Date,DATE_UNIT_MONTH)/3)+1)),"_",str(date_get(Date,DATE_UNIT_YEAR)))"/> </list> <parameter key="keep_all" value="true"/> </operator> <operator activated="true" class="date_to_numerical" compatibility="9.6.000" expanded="true" height="82" name="Date to Numerical" width="90" x="648" y="34"> <parameter key="attribute_name" value="Quarter"/> <parameter key="time_unit" value="quarter"/> <parameter key="millisecond_relative_to" value="second"/> <parameter key="second_relative_to" value="minute"/> <parameter key="minute_relative_to" value="hour"/> <parameter key="hour_relative_to" value="day"/> <parameter key="day_relative_to" value="month"/> <parameter key="week_relative_to" value="year"/> <parameter key="month_relative_to" value="year"/> <parameter key="quarter_relative_to" value="year"/> <parameter key="half_year_relative_to" value="year"/> <parameter key="year_relative_to" value="era"/> <parameter key="keep_old_attribute" value="false"/> </operator> <operator activated="true" class="date_to_numerical" compatibility="9.6.000" expanded="true" height="82" name="Date to Numerical (2)" width="90" x="782" y="34"> <parameter key="attribute_name" value="Year"/> <parameter key="time_unit" value="year"/> <parameter key="millisecond_relative_to" value="second"/> <parameter key="second_relative_to" value="minute"/> <parameter key="minute_relative_to" value="hour"/> <parameter key="hour_relative_to" value="day"/> <parameter key="day_relative_to" value="month"/> <parameter key="week_relative_to" value="year"/> <parameter key="month_relative_to" value="year"/> <parameter key="quarter_relative_to" value="year"/> <parameter key="half_year_relative_to" value="year"/> <parameter key="year_relative_to" value="era"/> <parameter key="keep_old_attribute" value="false"/> </operator> <operator activated="true" class="generate_concatenation" compatibility="9.6.000" expanded="true" height="82" name="Generate Concatenation" width="90" x="916" y="34"> <parameter key="first_attribute" value="Quarter"/> <parameter key="second_attribute" value="Year"/> <parameter key="separator" value="_"/> <parameter key="trim_values" value="false"/> </operator> <operator activated="true" class="replace" compatibility="9.6.000" expanded="true" height="82" name="Option_1" width="90" x="1050" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Quarter_Year"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="replace_what" value="\.0"/> </operator> <connect from_op="Create ExampleSet" from_port="output" to_op="Generate Copy" to_port="example set input"/> <connect from_op="Generate Copy" from_port="example set output" to_op="Generate Copy (2)" to_port="example set input"/> <connect from_op="Generate Copy (2)" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Date to Numerical" to_port="example set input"/> <connect from_op="Multiply" from_port="output 2" to_op="Second_Option" to_port="example set input"/> <connect from_op="Second_Option" from_port="example set output" to_port="result 2"/> <connect from_op="Date to Numerical" from_port="example set output" to_op="Date to Numerical (2)" to_port="example set input"/> <connect from_op="Date to Numerical (2)" from_port="example set output" to_op="Generate Concatenation" to_port="example set input"/> <connect from_op="Generate Concatenation" from_port="example set output" to_op="Option_1" to_port="example set input"/> <connect from_op="Option_1" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator> </process>
