Import Configuration Wizard not working?
WillDowdy
I am trying to use Import Configuration Wizard on a Read Excel operator, but the correct window for Import Configuration Wizard will not open. It only opens the Import Data window when I click it.
To be clear, I am clicking into Read Excel's Parameters, clicking Import Configuration Wizard, and the standard Import Data window opens.
Does anyone know how I might fix this?
Data Import
Jeff_Mergler
Hi
@WillDowdy
, I think you found a video in the Academy that was created in an older version; we need to update it. The screenshot you provided of your own process looks like the current wizard dialog. If you follow the lesson that
@MarcoBarradas
provided, it is more current.
Marco_Barradas
@WillDowdy
you need to go to your file select it and then the wizard eill help you with all the other tasks
WillDowdy
@MarcoBarradas
So what happens after I do that is it sends me through the standard Import Data process. I've provided a screenshot of that. What I would like to see is the window in the second picture I've provided from a tutorial video, which walks through a different import process.
Marco_Barradas
@WillDowdy
your second image is the first step of the wizard on which you'll pick the file you are going to work with.
The second image shows that you have already picked an you are working on the customer data sheet of that excel.
If that's not the file you want to work with click on previous to return and it should take you to step 1 ( your second image)
You are following this video right?
https://academy.rapidminer.com/learn/video/basic-data-loading-demo
WillDowdy
The video I am following is actually called "Data Preparation."
The second image is a screenshot of that video.
I haven't been able to see that "data import wizard" window on my own computer.
When I click into the Wizard, it just sends me to "data import" with no wizard features.
WillDowdy
@MarcoBarradas
forgot to tag you ^, thanks for helping by the way
sgenzer
cc
@jmergler
Jeff_Mergler
Hi
@WillDowdy
@MarcoBarradas
JamesH
Hi, I am having the exact same problem as Will Dowdy above, and I don't think it was really answered here. He correctly points out that the tutorial video for data loading shows the import configuration window when the Wizzard button is pressed, but when you actually press the button in RM, you simply get taken to the standard import data process. It is like the Wizzard button in the tutoriaal and real life are different .
Also the video he is referring to is not the one suggested by
@MarcoBarradas
above, but rather the video entitled 'Data Loading via a Process' in the RM academy under the 'Getting started wit RM' > 'Data Access and Preparation' section (at about 40 seconds into the video). The Wizzard is working in the tutorial, but in reality, when you click the 'Wizzard' button, you see what Will Dowdy above shows in his first screenshot. Could there currently be problem with the Wizzard?
Thanks in advance
KM_ALTR
Hi all, the issue here is that the video which is under discussion (
https://academy.rapidminer.com/learn/video/data-loading-via-a-process
) was created in version 7.6 it is outdated and simply needs to be redone as the functionality has slightly changed. However when you drag in the read Read excel and click the 'import Configuration Wizard' straight away without changing anything else in the parameters panel you will still get an open file dialog. Hope this helps and rest assured we will update as soon as we can to avoid any further frustration.
