<?xml version="1.0" encoding="UTF-8"?><process version="9.6.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value="yhuang@rapidminer.com"/> <parameter key="process_duration_for_mail" value="1"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="utility:create_exampleset" compatibility="9.6.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="246" y="289"> <parameter key="generator_type" value="comma separated text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="input_csv_text" value="Name,Rename Sachin,Sachin N Om,Om Rathi Sager,Sagi"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> <description align="center" color="transparent" colored="false" width="126">mapping dictionary for renaming</description> </operator> <operator activated="true" class="extract_macro" compatibility="9.6.000" expanded="true" height="68" name="Extract Macro" width="90" x="380" y="289"> <parameter key="macro" value="NN_RENAME"/> <parameter key="macro_type" value="number_of_examples"/> <parameter key="statistics" value="average"/> <parameter key="attribute_name" value=""/> <list key="additional_macros"/> </operator> <operator activated="true" breakpoints="after" class="utility:create_exampleset" compatibility="9.6.000" expanded="true" height="68" name="Create ExampleSet (2)" width="90" x="246" y="34"> <parameter key="generator_type" value="comma separated text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="input_csv_text" value="id,Sachin,Om,Sager 1,2,3,4 2,2,3,4 3,2,3,4"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> <description align="center" color="transparent" colored="false" width="126">any database table</description> </operator> <operator activated="true" class="set_role" compatibility="9.6.000" expanded="true" height="82" name="Set Role" width="90" x="380" y="34"> <parameter key="attribute_name" value="id"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="concurrency:loop" compatibility="9.6.000" expanded="true" height="103" name="Loop" width="90" x="648" y="34"> <parameter key="number_of_iterations" value="%{NN_RENAME}"/> <parameter key="iteration_macro" value="iteration"/> <parameter key="reuse_results" value="true"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="filter_example_range" compatibility="9.6.000" expanded="true" height="82" name="Filter Example Range" width="90" x="45" y="136"> <parameter key="first_example" value="%{iteration}"/> <parameter key="last_example" value="%{iteration}"/> <parameter key="invert_filter" value="false"/> </operator> <operator activated="true" class="extract_macro" compatibility="9.6.000" expanded="true" height="68" name="Extract Macro (2)" width="90" x="179" y="136"> <parameter key="macro" value="OLD_NAME"/> <parameter key="macro_type" value="data_value"/> <parameter key="statistics" value="average"/> <parameter key="attribute_name" value="Name"/> <parameter key="example_index" value="1"/> <list key="additional_macros"> <parameter key="NEW_NAME" value="Rename"/> </list> </operator> <operator activated="false" class="operator_toolbox:set_parameters_from_es" compatibility="2.3.000" expanded="true" height="82" name="Set Parameters from ExampleSet" width="90" x="313" y="340"> <parameter key="operator_name_attribute" value="FUNCTION_NAME"/> <parameter key="parameter_name_attribute" value=""/> <parameter key="value_attribute" value=""/> </operator> <operator activated="true" class="rename" compatibility="9.6.000" expanded="true" height="82" name="Rename" width="90" x="380" y="34"> <parameter key="old_name" value="%{OLD_NAME}"/> <parameter key="new_name" value="%{NEW_NAME}"/> <list key="rename_additional_attributes"/> </operator> <connect from_port="input 1" to_op="Rename" to_port="example set input"/> <connect from_port="input 2" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_op="Extract Macro (2)" to_port="example set"/> <connect from_op="Filter Example Range" from_port="original" to_port="output 2"/> <connect from_op="Rename" from_port="example set output" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="source_input 3" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> <portSpacing port="sink_output 3" spacing="0"/> </process> </operator> <connect from_op="Create ExampleSet" from_port="output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Loop" to_port="input 2"/> <connect from_op="Create ExampleSet (2)" from_port="output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Loop" to_port="input 1"/> <connect from_op="Loop" from_port="output 1" to_port="result 1"/> <connect from_op="Loop" from_port="output 2" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator> </process>
