<?xml version="1.0" encoding="UTF-8"?><process version="9.6.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="-1"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="pdf_table_extraction:pdfs2exampleset_operator" compatibility="0.2.001" expanded="true" height="68" name="Read PDF Tables" width="90" x="45" y="34"> <parameter key="resource_type" value="file"/> <parameter key="attribute" value=""/> <parameter key="tune extraction criteria" value="false"/> <parameter key="discard tables with no rows" value="false"/> <parameter key="discard empty attributes" value="false"/> <parameter key="heuristic ratio for table content" value="0.65"/> <parameter key="tune edge detection criteria" value="false"/> <parameter key="grayscale intensity threshold" value="25"/> <parameter key="minimum width of horizontal edge" value="50"/> <parameter key="minimum height of vertical edge" value="10"/> <parameter key="maximum cell corner distance" value="10"/> <parameter key="required text lines for edge" value="4"/> <parameter key="required cells for table" value="4"/> <parameter key="point snap distance threshold" value="8.0"/> <parameter key="table padding amount" value="1.0"/> <parameter key="identical table overlap ratio" value="0.9"/> </operator> <operator activated="true" class="loop_collection" compatibility="9.6.000" expanded="true" height="82" name="Loop Collection" width="90" x="179" y="34"> <parameter key="set_iteration_macro" value="false"/> <parameter key="macro_name" value="iteration"/> <parameter key="macro_start_value" value="1"/> <parameter key="unfold" value="false"/> <process expanded="true"> <operator activated="true" class="select_attributes" compatibility="9.6.000" expanded="true" height="82" name="Select Attributes" width="90" x="45" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <description align="center" color="transparent" colored="false" width="126">enter the attribute of example sets you want to keep</description> </operator> <operator activated="true" class="branch" compatibility="9.6.000" expanded="true" height="82" name="Branch" width="90" x="179" y="34"> <parameter key="condition_type" value="min_attributes"/> <parameter key="condition_value" value="1"/> <parameter key="expression" value=""/> <parameter key="io_object" value="ANOVAMatrix"/> <parameter key="return_inner_output" value="true"/> <process expanded="true"> <connect from_port="condition" to_port="input 1"/> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> <description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="132" y="13">keep the ExampleSet</description> </process> <process expanded="true"> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> <description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="162" y="13">do not keep the ExampleSet</description> </process> <description align="center" color="transparent" colored="false" width="126">branch to some minimum # of attributes (1?)</description> </operator> <connect from_port="single" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Branch" to_port="condition"/> <connect from_op="Branch" from_port="input 1" to_port="output 1"/> <portSpacing port="source_single" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="operator_toolbox:advanced_append" compatibility="2.3.000" expanded="true" height="82" name="Append (Superset)" width="90" x="313" y="34"/> <connect from_op="Read PDF Tables" from_port="collection of pdf data tables as example sets" to_op="Loop Collection" to_port="collection"/> <connect from_op="Loop Collection" from_port="output 1" to_op="Append (Superset)" to_port="example set 1"/> <connect from_op="Append (Superset)" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
<?xml version="1.0" encoding="UTF-8"?><process version="9.6.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="-1"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="pdf_table_extraction:pdfs2exampleset_operator" compatibility="0.2.001" expanded="true" height="68" name="Read PDF Tables" width="90" x="112" y="136"> <parameter key="resource_type" value="file"/> <parameter key="attribute" value=""/> <parameter key="tune extraction criteria" value="false"/> <parameter key="discard tables with no rows" value="false"/> <parameter key="discard empty attributes" value="false"/> <parameter key="heuristic ratio for table content" value="0.65"/> <parameter key="tune edge detection criteria" value="false"/> <parameter key="grayscale intensity threshold" value="25"/> <parameter key="minimum width of horizontal edge" value="50"/> <parameter key="minimum height of vertical edge" value="10"/> <parameter key="maximum cell corner distance" value="10"/> <parameter key="required text lines for edge" value="4"/> <parameter key="required cells for table" value="4"/> <parameter key="point snap distance threshold" value="8.0"/> <parameter key="table padding amount" value="1.0"/> <parameter key="identical table overlap ratio" value="0.9"/> </operator> <operator activated="true" class="loop_collection" compatibility="9.6.000" expanded="true" height="82" name="Loop Collection" width="90" x="246" y="136"> <parameter key="set_iteration_macro" value="false"/> <parameter key="macro_name" value="iteration"/> <parameter key="macro_start_value" value="1"/> <parameter key="unfold" value="false"/> <process expanded="true"> <operator activated="true" class="select_attributes" compatibility="9.6.000" expanded="true" height="82" name="Select Attributes" width="90" x="45" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <description align="center" color="transparent" colored="false" width="126">enter the attribute of example sets you want to keep</description> </operator> <operator activated="true" class="branch" compatibility="9.6.000" expanded="true" height="82" name="Branch" width="90" x="179" y="34"> <parameter key="condition_type" value="min_attributes"/> <parameter key="condition_value" value="1"/> <parameter key="expression" value=""/> <parameter key="io_object" value="ANOVAMatrix"/> <parameter key="return_inner_output" value="true"/> <process expanded="true"> <connect from_port="condition" to_port="input 1"/> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> <description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="132" y="13">keep the ExampleSet</description> </process> <process expanded="true"> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> <description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="162" y="13">do not keep the ExampleSet</description> </process> <description align="center" color="transparent" colored="false" width="126">branch to some minimum # of attributes (1?)</description> </operator> <connect from_port="single" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Branch" to_port="condition"/> <connect from_op="Branch" from_port="input 1" to_port="output 1"/> <portSpacing port="source_single" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Read PDF Tables" from_port="collection of pdf data tables as example sets" to_op="Loop Collection" to_port="collection"/> <connect from_op="Loop Collection" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
