Hi, How can I change and fix default variables like sleeve type, metal and mold type etc. in Inspire Cast. I want to fix them so that I don't have to change it every time when starting the software.
Thanks,
Jas
Hello Sourav
Parameters saved in Icast file are kept in this file only.
When a new file is opened you need to choose parameters again. it is not saved as default
Hello Sourav Parameters saved in Icast file are kept in this file only. When a new file is opened you need to choose parameters again. it is not saved as default
Uri,
Correct, Yes for the new file, we need to reassign them again. Thanks
Sourav
