Greetings,
We are working on a model with nodes >20M, performing AMSES modal solution and end up with quite a lot o modes. This leads to .h3d file size greater than 50 GB, causing post-processing in HyperView to be much harder. Is there way to reduce output size in OptiStruct to reduce output file size, maybe by following:
- Do not output results for all solid elements, but for faces of solid components
- Form a new approximate surface mesh for all components
- Omit modes with eff. mass values less than a specific value in all dofs
- Write more than one .h3d file with specified upper limit in file size
Thanks a lot in advance,
Koray
